3bar map into crx intl question
Old Jun 15, 2006 | 05:33 PM
Ch3mik's Avatar
Default 3bar map into crx intl question
I searched plenty far and wide. just wondering if anyone knows what wires go where for my GM 3bar map into a 1990 crx HF. I can get pics of the stock wires and the 3 bar if needed. someone help. thanks
alan
I know I need a multimeter and the values but im givin this a shot first to see if someone knows.
Old Jun 15, 2006 | 05:51 PM
cyph3r's Avatar
GND Pin A Green/White
MAP signal Pin B White OR Green/Red
5V Pin C Yellow/Red
Old Jun 15, 2006 | 07:36 PM
B18 CYA's Avatar
http://www.hondata.com/tech3barmap.html
Old Jun 15, 2006 | 09:07 PM
Ch3mik's Avatar
Default Re: (B18 CYA)
hey thanks so much guys for the fast response.
Old Jun 15, 2006 | 09:44 PM
KeyserSoze's Avatar
Default Re: (Ch3mik)
Here are the map sensor wires for obd1 and obd2 for future reference (if you ever need them). You can just save them onto your notepad for easy reference. Took me a while to find them to. But I am kinda slow.......
OBD1 Wiring Harness
A- goes to the Green and White wire which is ground
B- goes to the white with a yellow stripe which is the map signal
C- goes to the yellow with a white stripe which is the 5V Power
OBD2 Wiring Harness
B- goes to the red with a green stripe which is the map signal
C- goes to the yellow with a red stripe which is the 5V Power
GL.
Rand The Man
20
Sep 18, 2013 05:32 AM
R THIS
May 2, 2008 12:55 PM
B18EG6
Mar 28, 2007 12:36 PM
I B BANGGIN
Feb 6, 2007 07:50 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
