My turbo setup...complete?
Old Jun 12, 2006 | 10:06 PM
ex94vtec's Avatar
Default My turbo setup...complete?
Okay this is more of a "here's my setup...am i missing anything?" thread. I think i got it all...just want some opinions since I am going to have to take time of from work to get eveything in and tuned and i don't wanna take the time off onyl to find out i am missing parts and have to order them and wait for them to come in. Here are all the parts I have:
[x] Turbonetics T3 turbocharger
[x] Tial 38mm wastegate (.5bar spring)
[x] CNC aluminum IC piping
[x] Silicone couplers
[x] T-bolt clamps
[x] HKS BOV
[x] Oil feed
[x] Oil return
[x] Hondata S200
[x] RC 370cc fuel injectors
[x] Precision 350hp IC
[x] Spoolin log manifold
[x] Spoolin 2.5” downpipe
[x] Spoolin closed-loop dumptube
[x] GE vacuum manifold
[x] Autometer sport-comp boost gauge
[x] Autometer sport-comp oil pressure gauge
[x] NGK BCPR7ES-11
i am only going to run off the wastegate at first which will be about 7psi...so i am not expectiong more then 160-170whp...
Old Jun 12, 2006 | 10:13 PM
TheLastSpartan's Avatar
Default Re: My turbo setup...complete? (ex94vtec)
looking good to me. Just make sure you know some tuners to help get to your goal. GL and post results when your done.
Old Jun 12, 2006 | 10:26 PM
jdmcivicb16a2sc61's Avatar
Default Re: My turbo setup...complete? (TheLastSpartan)
a fuel pump couldnt hurt
Old Jun 13, 2006 | 05:19 PM
ex94vtec's Avatar
yea i might look into getting one...but i dont think it'll be necessary for now...any others?
Old Jun 13, 2006 | 05:24 PM
eh3 93's Avatar
Default Re: (ex94vtec)
Do you already have a 2.5" exhaust or bigger?
Old Jun 13, 2006 | 05:29 PM
ex94vtec's Avatar
yes
Old Jun 13, 2006 | 05:33 PM
Boostage's Avatar
charge pipes,oil restrictor,vacuum lines and T's and do u have the fitting for the oil pan where the return connects to?
Old Jun 13, 2006 | 05:40 PM
ex94vtec's Avatar
i have the charge piping...dont have a restrictor, need vacuum lines...dont need any T's will be using my GE vacuum manifold. and i believe the fitting came with my oil line package
Old Jun 13, 2006 | 05:46 PM
mike93boost's Avatar
youre gonna need a clutch.
Old Jun 13, 2006 | 05:52 PM
ex94vtec's Avatar
Default Re: (mike93boost)
sorry shoulda posted...i hav an act clutch already in....also have a new headgasket timing belt, waterpump and arp's already in
Old Jun 13, 2006 | 06:42 PM
eh3 93's Avatar
Gas money? jk
Old Jun 13, 2006 | 07:35 PM
ex94vtec's Avatar
Default Re: (eh3 93)
so does that mean that list list looks pretty much complete? lol
Old Jun 14, 2006 | 12:28 AM
Little off topic but will those 370cc's be enough for his setup? Like, what are the limits of those compared to the 440s or 450s people usually go for?
Old Jun 14, 2006 | 12:36 AM
Default Re: (TheLastSpartan)
once you go turbo, something weird happens to you...you have the sudden urge to keep upping the boost and make more power i cant explain it. i would go for 550cc-750cc
Old Jun 14, 2006 | 06:37 AM
ex94vtec's Avatar
Default Re: (jdmcivicb16a2sc61)
hah yea...i have heard about that...i will probably consider looking into bigger injectors...but i was told those 370's will be good for under 200whp and since i will be running off the wastegate until i get my hands on a nice ebc they should be sufficient...i mean unless that t3 gets me to 200whp on 7psi but i doubt it?
Old Jun 14, 2006 | 11:28 AM
i ran 370 when i had just a 12:1 fmu and stock ecu, because she wouldn't idle if they were bigger.
Old Jun 14, 2006 | 03:52 PM
ex94vtec's Avatar
do u guys think the 370's would be fine for under 200whp?
Old Jun 14, 2006 | 07:20 PM
Zakar's Avatar
FMU's suck..
i always recomend getting big ones right away.. your going to need to buy larger ones when you want more power (you will). 1000cc or bust
Old Jun 14, 2006 | 07:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex94vtec &raquo;</TD></TR><TR><TD CLASS="quote">do u guys think the 370's would be fine for under 200whp?</TD></TR></TABLE>
theyll be find for under 200..
you could always get some dsm 450s for pretty cheap.
Old Jun 14, 2006 | 08:25 PM
ex94vtec's Avatar
well regardless of how much i will want more power (and i know i will) im starting school in september and car funds will be lowww for a while and unless i get a boost controller i will be running off the wastegate which will be 7psi so i think these 370's will be good for the time being...altho i think i will upgrade to some 550's down the road when i get some extra play money!
Old Jun 14, 2006 | 08:59 PM
Zakar's Avatar
550's are such a waste.. 750's arent much more at all...
Old Jun 14, 2006 | 10:12 PM
Default Re: (Zakar)
i have 550cc im happy but i sure 750cc will start looking good soon.
Old Jun 15, 2006 | 11:26 AM
ex94vtec's Avatar
Default Re: My turbo setup...complete? (Boostedhatch94)
aright thanks for all the help... i am just awaiting the arrival of my parts from SPoolin...once those come in i will start putting it all together then bring it to get tuned...i will definetly post up some results from the dyno day
Old Jun 15, 2006 | 11:35 AM
GiNuWiNe's Avatar
I'm in the same boat :D, hopefully i'll have my spoolin stuff on before college starts again this fall. Good luck on your setup and it looks like your list is pretty complete. A wideband air fuel meter wouldn't hurt though .
Old Jun 15, 2006 | 11:51 AM
ex94vtec's Avatar
Default Re: My turbo setup...complete? (GiNuWiNe)
yea i ordered my spoolin manifold package back in april...i am hoping it gets here any day now...school starts for me in september...i better be done and boostin by then!
