having problem tuning my car with zeitronix 3.5 bar map w/ hondata s100b..
my car show really rich under 1k rpm(around 10. a/f range). even with alot of fuel taken out or adding a lot of fuel. the a/f still show 10a/f range. if the rpm range is above 1k then the a/f will jump to 12 to 14a/f. the auto meter boost guage and my zeitronix display guage does not show the same readings. i don't know which one is the correct numbers to tune off with. one thing about hondata is that it can only support up to a 3 bar map only. so im not sure if my 3.5 map with throw the reading off. anybody having the same problem or use a 3.5 aem style map sensor on any hondata s100b or s200b? help me out
Re: (eg:R)
I don't believe the Hondata S-series supports the 3.5 AEM/Zeitronix/Klevico sensor. You need to manually edit the mbar table via a hex editor. Your datalogs will all be off though. But the actual table of reference will be correct, and thats most important. GM 3bar settings will not work with the 3.5bar sensor so don't even bother trying.
Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R »</TD></TR><TR><TD CLASS="quote">so u mean i can't used a 3bar for my zeitronix</TD></TR></TABLE>
i dont think hondata can use the 3.5, only the GM 3 bar, and the 5 bar
b20turbocivic
08-12-2010 07:06 PM
eg:R
06-11-2006 05:39 PM
