Please help!!
Old Jan 20, 2025 | 04:17 PM
D_18C1JRSC's Avatar
Default Please help!!
Ok I bought a 91 CRX Si, has a decent built B18c1 with a JRSC. It has a AEM A/F gauge and on the back of the gauge it says only use LSU 4.9 wideband O2 sensor. Well I ordered a new Wideband O2 the one it says to use, I get the car up in the air before I try to take the O2 out I check the plugs and it’s the wrong plug it doesn’t fit.. So then I just focus on checking out the Gauge wires and it wasn’t even hooked up well correctly anyways. So I go to tie into A25 A26 and D14 but they arnt the wires that are supposed to be in those pins?!!! I’m so Fing confused!!!
Old Jan 20, 2025 | 05:07 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Please help!!
To wire up the AEM wideband gauge, do the following:
1. RED (+12VDC ignition)….wire it into the 3rd option slot at the underdash fuse box(see the image below)
2. BLACK (ground)….wire it to a good grounding point. Any existing threaded hole at the driver kick panel will suffice
3. WHITE (analog +)……cut the wire at D10 at least 3 inches away from plug. Tape off the cut side leading into car. Connect into the wire leading to ECU plug.
4. BROWN (analog -)…..tap into D21 or D22. Solder connection and cover with electrical tape
Old Jan 20, 2025 | 06:53 PM
D_18C1JRSC's Avatar
I forgot to add I have a chipped p28.. What is Pin D10??
Old Jan 21, 2025 | 05:50 PM
NVturbo's Avatar
O.G. triple O.G.
D10 is ELD (Electrical Load Detector). And no, you do not need to modify your ECU to make it work. People use to claim that 2 resistors need to be removed….they don’t.
peddyeye
Dec 1, 2008 01:52 AM
hondaguyexsi
Oct 8, 2005 06:58 PM
hatchy
Aug 23, 2002 10:41 PM
HX_Guy
Aug 30, 2001 07:31 AM
