Shifter Problems?
Old Sep 2, 2024 | 03:50 PM
rs3s's Avatar
Default Shifter Problems?
Can anyone help me figure out whats going on with my shifter? Whenever I put my foot on the gas and im coming off the clutch my shifter is moving further up or down into whatever gear its in. I haven't had any problems until now and dont got a clue what it is. I also have a skunk2 short throw if that changes anything
File Type: mov
Old Sep 3, 2024 | 08:11 AM
Maxcapacity's Avatar
Default Re: Shifter Problems?
Your engine mount bushings are possibly torn and worn out. Easiest to check would be the front first.. The engine is simply twisting, pulling and pushing on the linkage moving the shifter around...
Old Sep 10, 2024 | 04:35 PM
rs3s's Avatar
New problem now, was just looking at my mounts and the bolt that goes through the rear mount just so happens to be missing and non existent. Would you happen to know the specs for said bolt?
Old Sep 10, 2024 | 08:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
12mm x 1.25 pitch... I think the length is about 110mm, but you can be sure of the length by measuring from one side of the rear bracket to the other (and add about 10-15mm so some threads stick out of the welded on nut).
white_db8
Jun 28, 2007 02:53 PM
hialeahzbg
Jul 30, 2005 07:41 AM
EJ8VTEC
Apr 10, 2005 02:02 PM
Kermit EK
Jan 10, 2003 07:24 PM
DJ:A
10
Jul 14, 2001 07:02 PM
