MANY PROBLEMS PLEASE HELP
Old Sep 27, 2009 | 07:06 AM
mister m 83's Avatar
Default MANY PROBLEMS PLEASE HELP
90 integra b16a obd0 4 door 178000 on body about 65000 on motor. NO CODES!!! I have tried a different ecu too!! The car sat for 3 years without a motor in it and here are my problems... No vtec... wiring is good had rs motors in burnsville mn check it. Idles high... Like 1500 but drops to 1000 when i tap the gas or turn my steering wheel to make the power steering pump run... No fan.. There are like 4 relays behind my headlights and i guess i dont know if that might be the problem or which one it might be.. temp gauge works and actually all of these thighs i have listed worked fine in my civic so...... Anyone please help me!!!!
Old Sep 27, 2009 | 04:11 PM
dunkXdrift831's Avatar
Default Re: MANY PROBLEMS PLEASE HELP
could be a bad vtec solenoid or the wiring is wrong. as for the high idle. did you adjust idle? could also be a vacuum leak.
Old Sep 28, 2009 | 09:27 AM
The wiring is good and i did adjust my idle the screw is all the way in and i know 100% my vacuums are right because i looked at a friends crx woth a b16 and thy are the same
92lx
Feb 18, 2013 08:18 AM
92lx
Feb 14, 2013 07:25 AM
Dyl@n
Apr 29, 2011 08:11 AM
civic_jones
15
Nov 14, 2009 06:32 PM
