whats needed for a 5sp conversion?
Old Oct 1, 2009 | 11:57 AM
teggyjeff's Avatar
Default whats needed for a 5sp conversion?
well i have a 98 automatic db8 ls integra and im planning on doing a k24 swap ok but my questions are what parts do i need so i can just do the swap like other then the pedal assembly what else do i need so i can get this done so if anyone can help me out on this that know about this or have done it before fill me in with all the info u know or have thanx
Old Oct 1, 2009 | 12:09 PM
vladd's Avatar
Default Re: whats needed for a 5sp conversion?
clutch line and clutch cylinder. the wiring is different so you'll have to modify that.
Old Oct 1, 2009 | 01:11 PM
dalejrfan88's Avatar
I know on my DA i needed pedals, shift linkage, flywheel, clutch, and trans of course. You may need an auto to manual conversion mount. Im not sure if the ecus are different so you may want to look into that.
Old Oct 1, 2009 | 01:55 PM
MCDizzL3's Avatar
New User
I just finished my 5speed conversion on my 94 NTeg.. & it was perfect the 1st time I drove it.
- Hasport makes a 5 speed conversion mount for the tranny- about $140 that you will need. ( i saw a diff one on ebay for $50 used )- & you will need to get a manual ECU or spend $25 to convert yours.
- Also you have to bypass the nuetral safety switch to be able to start car in gear. If u have any other Qs just ask
Old Oct 1, 2009 | 05:31 PM
vladd's Avatar
he'll already be changing the ecu and everything else with the k24 swap.
Old Oct 1, 2009 | 06:07 PM
follie gatts's Avatar
you win first post
DAGAME
Sep 8, 2007 05:47 AM
helpisneeded
Sep 18, 2005 01:11 PM
1JDMDOMINICAN
Aug 2, 2004 02:55 PM
LS_teg07
Feb 18, 2004 01:10 PM
jdmhatch
Jan 1, 2002 05:23 AM
