ecu question with swap
I am swapping a jdm obd1 b16 motor into a 1996 obd2 integra... obviously i have to make it obd1. i have an obd1 wiring harness, an obd2 to obd1 jumper harness for the ecu, and an obd1 ecu... my question is - Is that all that is necessary to run that motor in the integra and have it run correctly?
Thanks in advance,
- Jared
Thanks in advance,
- Jared
Now can somebody please answer my question?
wtf is this?............https://honda-tech.com/forums/acura-integra-6/b16-wiring-da-2654896/
yes, that is all you need to get that motor running in your obd2 car..only thing im hesitant on is if the obd1 wire harness plugs right into the obd2 harness along the firewall on the engine bay? if it does then its plug and play for everything else
yea i checked it out and it plugs right in. thanks for the help
Panda Eg6
May 14, 2008 10:05 PM
