tranny problems...
Old Oct 1, 2009 | 11:00 AM
2k1_gsr's Avatar
Default tranny problems...
hi guys...ive been having issues with my tranny. if i get on it and shift to 2nd sometimes it wont engage and feels like im hitting a brick wall or it will just miss and grind. last night i went to a track event and now sometimes the car gets stuck in 1st gear and im having trouble shifting gears 1-3. the tranny feels like theres obstruction.... any advice on how to diagnose would be very appreciated.
mods:
01 dc2
81.5mm itr pistons
ctr cams
exedy street clutch
aem cai
greddy sp2
thanks!
Old Oct 1, 2009 | 11:06 AM
S2Integra's Avatar
Default Re: tranny problems...
First thing is to check fluid levels in both clutch resivoir and tranny itself. I seem to think that it is more serious, like debris in the gear drives. How is the clutch engagement. The clutch slave sometime leaks a littl and you have to bleed it. Mine seized and I had to replace it. I was having a real had time getting into gear.
Old Oct 1, 2009 | 12:11 PM
2k1_gsr's Avatar
thanks ill check that out....someone told me its the shift linkage? any 1 have similar problems?
Old Oct 1, 2009 | 01:03 PM
OH_1fstgsr's Avatar
When checking the shift linkage make sure both bolts are in all the way at shifter end. I had one come out and the other half out and had similar shifting issues. I still never figured out how they came loose. I just check them last week and they are ok.
Old Dec 9, 2009 | 08:32 AM
starbai's Avatar
did you ever come up with a solution/diagnosis? just curiousl.
Old Dec 9, 2009 | 07:17 PM
villarino1k's Avatar
i had the same problem and did was said above. try it out if you havent figured it out
JRSC01GS-R
Transmission & Drivetrain
Apr 13, 2014 04:35 PM
nmb16a
Jan 31, 2010 07:43 PM
jayhwk75
10
Aug 22, 2005 02:29 PM
DubyaAye
Sep 22, 2004 06:23 PM
BrokeAssAcura
Sep 29, 2003 05:15 PM
