Catalyst low efficiency?
Old Sep 25, 2009 | 11:56 PM
thanh4o8's Avatar
Default Catalyst low efficiency?
Earlier coming home i hit a huge dip.
It was horrible. CEL came on.
i ran the code and it came up,
Catalyst low efficiency. What does
that mean?
Old Sep 26, 2009 | 12:34 AM
1993-eg1's Avatar
Default Re: Catalyst low efficiency?
no real idear. but isn't the stuff in the cat called catalyst? maybe try the 2ed o2
Old Sep 26, 2009 | 12:38 AM
racebum's Avatar
google the code, you'll get a detailed walk through
Old Sep 26, 2009 | 09:21 AM
HondacivDX's Avatar
the cat is not working like it should. low efficiency not cleaning up the exhaust polluntants like it should... prob bad cat or downstream o2 sensor
Old Sep 28, 2009 | 08:43 PM
thanh4o8's Avatar
bump
Old Sep 28, 2009 | 08:50 PM
Spawne32's Avatar
catalyst efficiency i believe is the cat converter, which means if you have that code your obd2, so you need to check what you damaged underneath the car. Hopefully you didnt rip the sensor wire out or something along that line.
Old Sep 28, 2009 | 09:17 PM
mrdeadman's Avatar
They let me pick
Crawl underneath and check your sensor for damage. If it is not, then pull your cat and look at it to see if the honeycomb is damaged.
doubleoazn03
Mar 3, 2018 02:06 PM
scott_turner
Apr 30, 2011 04:14 PM
nutball72
Aug 10, 2007 03:05 PM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
