basic teg q's
Old Oct 3, 2009 | 12:29 AM
felixjr18's Avatar
Default basic teg q's
ok my drivers side window stopped working all of a sudden and before it went out if i toggled the switch up twice and then down the window would go down. now it wont and idk if the switch went bad or a relay? if so where is it (relay) on a 98 integra.. also my motor mount move a lot suring reving and i figure their done. so i was wondering if i should just by poly inserts or jus replace with oem cant afford solid mounts so thats not a choice. also my srs light is on and its getting old and i wanna turn it off how would i go about that and also if i wanna run a aftermarket steering wheel will this turn the light on?
Old Oct 3, 2009 | 06:18 PM
felixjr18's Avatar
Default Re: basic teg q's
bump want my window working!!!!
Old Oct 3, 2009 | 06:55 PM
ag92gsr's Avatar
check your fuses for your windows or usually your window motor/switch is dead. Happened to me, got a used one from the junk. Or carefully pry open your door panel and check your harness, it might just be loose. Your motor/switch should be in there too I believe, its been a while since I did mines, but I am sure its there.
And your SRS light, check your fuses under your dash (drivers side) check the srs fuse to make sure its still good. Thats all I can think of now.
Old Oct 4, 2009 | 12:22 PM
felixjr18's Avatar
im thinkin it has to be the switch because my windows went up and down fine but the drivers side switch seems loose but if up press it to go up the lights dim as if it gets power and before it stopped working if you tapped the switch up twice or so then down it would go down jus fine but never had trouble going up
Old Oct 4, 2009 | 12:38 PM
racebum's Avatar
switch or window reg. both are common failure items. i have a spare switch cluster if you need one, that whole thing comes all as one part $30 shipped. window motors are kinda spendy for remans and hard to find at junk yards. remans are around $120 + shipping i actually have a working motor and regulator assembly laying around as well but the motor is on its last leg, it works, just is weak. i'd prolly do $50 shipped for all of it.
JoeDel
Honda CR-V & Element
Dec 3, 2016 02:01 PM
Edgemingsr
Jun 2, 2004 10:08 PM
BACKintheDA
Apr 18, 2004 04:05 PM
dskny
Mar 26, 2003 04:23 PM
