A/C and Radio stop working
I have a 1992 Acura Integra GS 2dr. When I got the car, everything worked and it ran fine, but recently, the a/c quit working and soon after that, the radio as well.
I have checked all the fuses in the car and under the hood; all are fine. I have also checked the ECU and it is not throwing any codes nor a check engine light.
I have no idea what the problem is, but I'm thinking an electrical problems under the dash?
Thanks to anyone that helps.
Re: A/C and Radio stop working
Its probably your Alternator going out. Its not giving back enough juice I guess. Same thing happend to me, the A/C and radio just shut off randomly and on again after I moved around the radio. But I also had sudden overheating also. Once it got enough battery power everything started working normally. Or perhaps check even a wire cross in the stereo harness. Check around there before anything. Make sure no wires are sticking out or touching metal.
I've checked to make sure nothing was crossing. I left my headlights on the other day and my car died. My dad had to come jump start me and after he did that, my a/c and radio started working but only for a short while.
Yeah I'm guessing low battery level or alternator not charging it enough.
Take a battery tester, start your car and turn on your headlights. If battery level drops fast then alternator is not charging enough.
almostjdmeg
04-08-2008 07:05 PM
