Engine Compression?
Old Feb 8, 2002 | 12:29 PM
DrewGSR's Avatar
Default Dealership just told me
I just took my car to the dealership to get it check out cuz for one i had the check engine light on (yellow/orange color), coolant leak, and my valves needed to be realigned cuz i did a bad misshift at the track.
Well, they just finished the valve realignment and fix the leak. Then they just called me and said the reason i have the check engine light and loss of power is cuz in my #4 cyclinder is running at 52 psi which is suppose to be really low from what he said. I don't how much psi is suppose to be in there or anything really technical like that. They qouted me $680 to remove something so they can figure what it is and fix.
[Modified by DrewGSR, 9:30 PM 2/8/2002]
[Modified by DrewGSR, 9:31 PM 2/8/2002]
Old Feb 8, 2002 | 01:49 PM
non-VTEC's Avatar
Default Re: Dealership just told me (DrewGSR)
a GS-R should have 200-220psi in all 4 cylinders. maybe a little less depending on the milage.
you have 52psi.........there is something seriously wrong there........have them check out the problem and i hope you have warentee still or else your gonna have one huge bill.......
Old Feb 8, 2002 | 05:20 PM
nfn15037's Avatar
Default Re: Dealership just told me (non-VTEC)
52 psi is NO good. I just did a compression test on my 88k mile GSR and it was 210 across the board. And lemme tell ya, they werent easy 88k miles either
Old Feb 8, 2002 | 05:27 PM
ATYPR's Avatar
You need to get a Pinto, that will fix everything. Ask the service writer at the dealership about it, he'll tell you.
jdmkidd23
Mar 5, 2010 08:09 AM
2.0L_of_fun
Jan 22, 2010 11:51 PM
sjthaxter
Nov 5, 2007 09:10 AM
LS-T
Oct 27, 2002 07:35 PM
B17aTrbo
Oct 19, 2001 05:33 PM
