exedy clutch problem
just installed a set of new exedy clutch & cover. shattered the old one (an exedy too). same problem, engagement very stuttery at low rpms, but ok at rpm higher than 2500. problem same in reverse too. feels like the new clutch doesn't grip properly. but hey, its new and the old clutch gas the same problem too. the clutch pedal doesn't feel as hard as my other teg R with same exedy clutch. he has no stuttering engagement problems too.
please help!
please help!
you have a 3 puck ceramic clutch.
did you expect a smooth stock like engagment?? it's bassically a race clutch......that's the way it's supposed to be.
still don't understand why same clutch has different effect on the same application?
I have the same setup: Exedy 3-puck race clutch with the Exedy chromoly 4.1kg flywheel. The first 200 km, the clutch engagement was very grippy with chatter.
[Modified by Project X, 1:16 PM 2/11/2002]
i had run about 2-3000 kms. shouldn't be the running-in issue here. my friend's exedy is installed at about the same time and i've covered more km than him.
could it be my clutch pump or something like that, or my mechanic messed up during the installation?
