Header??? What to Get???
Old Feb 15, 2002 | 11:36 AM
vtec8k's Avatar
Default Header??? What to Get???
What's up ppl. I wnat to get a header but have NO idea what to get....I do have a price range...no more than $450. That knocks off Mugen, Spoon, Hytech and prob. SMSP. I have heard really good things about JG edelbrock headers. Any experiences????
Also 4-2-1 or 4-1? i am not a track racer....more of a daily driver/road racer.
Thanx.
Leo
Old Feb 15, 2002 | 01:07 PM
Leimokei's Avatar
New User
Default Re: Header??? What to Get??? (vtec8k)
DC Sports 4-2-1...(ceramic if you want to keep the car for 2-5 years, stainless if your running nitrous...last longer...)...
4-2-1 design low end to mid range power...perfect for daily driver...$260-$380
Old Feb 15, 2002 | 01:14 PM
GTEater's Avatar
what kind of car do you have?........i heard JG header is not bolt on and some welding is required
if you have a gsr, i would go with DC JDM 4-1 which i will be getting soon.......i got a dc ceramic 4-2-1 about 4 years ago and its got a crack in the y pipe primaries.......you will also need a custom cat which will run about 165......or a staight pipe(but it makes the car sound like ****).......with your budget, you should be able to get everything, excluding labor..........or you can also go with the JDM ITR 4-1, but it will run about 100 bucks more, but the DC 4-1 made more power on the low end than the JDM ITR
Old Feb 15, 2002 | 01:21 PM
B00ST2nR's Avatar
Default Re: Header??? What to Get??? (GTEater)
DC 4-1! They're VERY nice and cheaper than the JDM's. The DC 4-1 Header made better low end power than the JDM, but the JDM made higher Peak HP. The 4-2-1 Design is all mid range gains. I'd go with the 4-1... I did.
Old Feb 15, 2002 | 02:06 PM
maxxdout's Avatar
Default Re: Header??? What to Get??? (GS-Racer)
Just got my Greddy 4-2-1. Love it, great quality as well. 301 shipped from a groupbuy
Old Feb 15, 2002 | 03:21 PM
1GreyTeg's Avatar
Yeah, what car is this for?
If for a GSR, I'd get the JDM 4-1 or the JDM DC/4-1. The 60mm collector is what you are looking for here, You'll also need a new cat for these.
If for the LS/SE or RS, I'd get the DC SS 4-2-1, good for all around town but don't expect some miracle oil, it WON'T produce any staggering gains for these cars. I list the SS because I've heard countless stories of the Ceramic coating cracking prematurely.
In general 4-1 is usually for higher end gains with a little loss down low, and 4-2-1 is for mid range without as much high-end than a traditional 4-1. There are also hybrid 4-2-1's like the Spoon that you are already counting out for price. The hybrids produce gains across the board with minimal sacrifice.
Here's a link to the header test so you can look at the JDM 4-1 and DC/JDM: http://www.automotiveperformanceengi...om/header.html
Good luck,
A.
Old Feb 15, 2002 | 04:14 PM
vtec8k's Avatar
Default Re: Header??? What to Get??? (1GreyTeg)
Sorry for the missing Info....this is a 2001 GSR. Mods. will include AEM CAI, Header????, ITR full cat back exhaust, and USDM ITR pistons (near furure), ITR LSD(near future), ITR Rear sway bar, H&R OE springs, skunk2 shortshifter.
Other than the welding issue with the JG edelbrock, is the header any good at producing power? JG's dyno has this header making up to 9 more hp than the same car with DC sports header (4-2-1), and the gains are throughout the rpm range.
If I decide NOT to get the JDM DC sport 4-1, what should I get? I have read that since the diameter of the pipe is bigger (2.5") i will loose low end power and get high end, aka 5000rpm on. What do you think?
Thanx.
Leo
Old Feb 15, 2002 | 04:18 PM
six_speed's Avatar
JDm 4-1......high end power is what's important. Help that Vtec kick like a donkey!
Old Feb 17, 2002 | 10:36 AM
GTEater's Avatar
Thanx.
Leo
recent dynos of the jdm and dc jdm 4-1 shows that you actually gain low end power(but that test was done on an ITR, so the higher CR, bigger cams, and different IM might have a role in those results)
a guy i know said he has the dc 4-1 and lost a noticeable amount of low end on his gsr
vtec2190
Feb 6, 2008 12:30 PM
joek84
Nov 23, 2003 09:06 PM
DaNish
Oct 9, 2001 06:47 PM
