test pipe
Old Apr 17, 2002 | 01:32 PM
integraty's Avatar
Default test pipe
I've got a 94 Gs-r that I took off the cat and was told was clogged. I gutted out the cat and clened it up and reinstalled it. I t made a noticeable difference in my car. I haven't had any check engine lights, and was thinking of putting a pipe in the cat to make it flow better. I'd put it right up to the O2 sensor, but keep the sensor on. what do you guys think?
Old Apr 17, 2002 | 02:03 PM
B18 B e a s T's Avatar
Default Re: test pipe (integraty)
I wouldn't get a test pipe. Just get a cat converter cause
1. Test pipe is illegal in most states and the fine is HUGE.
2. Test pipe makes your car sounds high pitched and raspy.
3. Test pipes make your car smell like gas.
Old Apr 17, 2002 | 02:06 PM
integraty's Avatar
Default Re: test pipe (B18 B e a s T)
What's a cat converter? I sthat where you just put a piece of pipe in the cat?
Old Apr 17, 2002 | 02:22 PM
threatcon13's Avatar
New User
just get a carsound hi flow cat.
Old Apr 17, 2002 | 02:32 PM
integraty's Avatar
Default Re: test pipe (ALLMOTORDC2)
That doesn't really answer my question.
Old Apr 17, 2002 | 02:57 PM
SIK IN DA HED's Avatar
New User
just leave it the way it is. puttin in a pipe wont really make a big difference. but you can try it out...
Old Apr 17, 2002 | 03:07 PM
hybridreams's Avatar
Catalytic converter is the techincal name for what you just gutted.
Old Apr 17, 2002 | 03:20 PM
Erik_Pb_Foot's Avatar
New User
Though you say you felt a difference after gutting the cat, that is probably just b/c it was clogged. A cat that is fuctioning as it should would flow "better" than a gutted cat since their is a great amount of turbulance created in the now gutted cat. Carsound is the way to go if you replace it, which you should. You won't throw any codes b/c you have no sensors after your exhaust manifold due to the OBD1 your car pocesses.
-Erik
[Modified by Pb_Foot, 7:21 PM 4/17/2002]
Old Apr 17, 2002 | 07:54 PM
integraty's Avatar
Default Re: test pipe (hybridreams)
never heard it called a cat converter. I'm stupid sorry.
Mhollaek9
May 2, 2007 09:14 PM
loner714
Apr 25, 2007 05:15 PM
User 5426
Sep 20, 2003 08:30 PM
808State
May 14, 2002 11:12 AM
00PurpleGSR
Apr 13, 2002 03:29 PM
