NEED HELP!!!! (having problem removing axel)
Old Sep 3, 2002 | 02:30 PM
Doogie Howser's Avatar
Default NEED HELP!!!! (having problem removing axel)
I am trying to take the half shaft out of the hub, it is stuck in the though, ive been pounding at the axel bolt but it wont come out, i have also tried prying it out of the hub but that wont work... ANY IDEAS!!! PLEASE
Old Sep 3, 2002 | 02:39 PM
teg92's Avatar
Default Re: NEED HELP!!!! (mlambrecht)
Sorry man sometimes it just gets baked in there. I had to take my whole spindel with upper arm, rotor & axle to a shop and they had to heat the guy up with oxy-acetelyne.. Not too friendly on the bearings however but it was my last resort.
Old Sep 3, 2002 | 02:44 PM
Default Re: NEED HELP!!!! (teg92)
are just suppose to be able to hammer at the axel nut and is it suppose to pop out? are there any other ways to take it out
Old Sep 3, 2002 | 02:49 PM
teg92's Avatar
It should actually just slip out, sometimes a little hammering, but in your case and my first time, it requires a lot more
Old Sep 3, 2002 | 03:56 PM
anyone have any other ideas
this is where i am at right now
Old Sep 3, 2002 | 04:01 PM
teg92's Avatar
Well first off, try soaking the opening to the splined section from the other side with release all or some sort of nonflammable liquid wrench product. If it still doesn't budge, then you can get your torch out and start heating it up as hot as you can and then try again. If that still doesn't work, keep spraying the liquid wrench stuff on, heat it up and then spray it with cold water. The rapid heating & expanding sometimes does the trick.
Good luck.
Old Sep 3, 2002 | 04:03 PM
teg92's Avatar
by the way, I hope you're not just trying to hit it as is without it connected to the tie rods or anything. You need to bang that thing out pretty good when it gets stuck, so I recommend either getting some suicidal guy to hold it or mount it back up to the tie rod to get some sort of support.
Old Sep 3, 2002 | 04:14 PM
Dee's Avatar
Dee
If you keep beating the nut you are either going to mess up the threads or moshroom the end of the shaft. Remove the entire hub/shaft assy and use a hydraulic press to break the shaft loose.
Old Sep 3, 2002 | 04:26 PM
Default Re: NEED HELP!!!! (Dee)
i think i did mushroom it...
Old Sep 3, 2002 | 04:59 PM
teg92's Avatar
Been there, done that. I'd really recommend trying what I said now or just bringing the whole spindle to a shop and have them press it out. S8it happens.
Old Sep 3, 2002 | 05:14 PM
how much are the rubber boots that go on the ball joints because already 2 of 3 are bursted and rip
[Modified by mlambrecht, 3:50 AM 9/4/2002]
Old Sep 4, 2002 | 07:39 AM
NA-GSR's Avatar
I'm in the middle of all this myself too so I feel your pain. Took me a week of cursing and bashing to get both my axles out and in the process I managed to:
1. mushroom 5 or 6 wheel studs.
2. mushroom both lower ball joints.
3. tear both ball joint boots.
wheel studs run $3 each, ball joints $20, ball joint boots $3.
my advice...take your time and watch where you're swinging that sledgehammer....
Old Sep 4, 2002 | 01:25 PM
Default Re:
how do you guys get this out?
Old Sep 4, 2002 | 01:41 PM
MPH's Avatar
MPH
New User
A couple bucks a piece including the rings
Old Sep 4, 2002 | 01:46 PM
GSRaCeRbOI's Avatar
Default Re:
I've never done this before so I'm just guessing.. but a slide hammer doesn't work in this application?
hmm wierd.. y did it tell me the post title can't contain more than 1/2 capital letters.. this isn't my post title... ok well I guess I'll delete everything except "RE:"
Old Sep 4, 2002 | 06:56 PM
Dee's Avatar
Dee
Default Re: Re: (GSRaCeRbOI)
Use a grinder to clean up the mushroomed part. If you mushroomed 3 or less threads the shaft is still usable. After cleaning up the mushroomed part use a hydraulic press (machine shop) to remove the shaft. After the shaft has been removed use a thread file to clean up the threads. When you re-install the shaft add some of grease to the splines of the shaft and hub. I did this for a friend a year ago because he didn't want to buy a new shafts after he atomic bomb mushroomed the ends of his shafts. He has been using these cleaned up thread shafts since last ummer with no problems.
Old Sep 4, 2002 | 08:03 PM
Default Re: Re: (Dee)
c
Old Sep 4, 2002 | 08:04 PM
i have finished putting the axel in, now i need to put 2 quarts of tranny fluid in, im wondering what you guys use to put in the fluid, do you use some kind of pump?
Old Sep 4, 2002 | 08:20 PM
Dee's Avatar
Dee
Default Re: Re: (mlambrecht)
Right above the drain plug is oil inlet plug. If you do not have a pump use a funnel with a long *** clear hose to fill the tranny with 2.2 liters of fluid.
Old Sep 4, 2002 | 10:33 PM
HeikDiesel's Avatar
When I took my axles out, the passenger side was easy. I broke the bolt that holds the hub together, undid the upper A-arm, took the shock fork out and then pried with a huge screw driver....poped right out. Other side was a little tougher. I had a friend help me because I didnt know there was a mount on the carrier bearing that bolted to the block. I hope I helped a little
wunPOINTeight
Jun 15, 2021 06:37 PM
KING_LIAN
Oct 3, 2007 07:35 AM
teddy_dc2
Jul 9, 2006 08:10 PM
Civicracer17
Mar 19, 2006 08:33 PM
Doogie Howser
Sep 4, 2002 06:18 AM
