antenna install
Old Sep 2, 2002 | 11:21 PM
ABLUEINTEG97's Avatar
Default antenna install
hey
does anyone know where i can get an s2000 antenna install that is clean for a 97 intag?
i live in L.A. i was wondering how long it would take and how much it would cost.
thanks
Old Sep 3, 2002 | 11:59 PM
Default Re: antenna install (ABLUEINTEG97)
is this a bad idea or something?
Old Sep 4, 2002 | 12:24 AM
Kyoung05's Avatar
A guy on Honda-Tech sells kits. Do a search on the topic, and you'll come across the thread. It's like $16 shipped, and you buy your own S2K antenna from the dealership. I personally like the Honda Insight antenna better and decided to go with that. My stock antenna had broken off, so for me it was cheaper to go this way. If your stock one is still fine, I wouldn't bother. The install takes about 30min., probably less, but you'll want to adjust the antenna into a position you like, and make sure its a snug fit by adjusting these nuts/washer on the install kit, which takes some time.
Old Sep 4, 2002 | 12:44 AM
vtecdc2's Avatar
i personally like mine more than the s2000. its a direct bolt on, no custom crap, and better reception.. thats just my opinion tho...
Old Sep 4, 2002 | 11:35 PM
Default Re: antenna install (VTECDC2)
thats a pretty sweet antenna. what kind is it? how long does it take to put on?
thanks
Old Sep 4, 2002 | 11:43 PM
vtecdc2's Avatar
took about 10 mins to put on after i removed some of the back panels.. i got it off ebay from some guy named locustom or locustoms.. i forgot.. its a 2 wire connection, just the antenna wire, and a power wire. the power wire boosts the radio signal.
Old Sep 9, 2002 | 12:25 AM
Default Re: antenna install (Kyoung05)
what do i need to do to install the antenna? is there any special part that i need to get, and how is the reception after the install?
thanks
Old Sep 9, 2002 | 12:56 AM
vtecdc2's Avatar
no special parts needed. install is as simple as removing the old antenna, and replacing it with the new one, tighten the locking nut, and connect 2 wires.
Old Sep 9, 2002 | 07:32 AM
vtecnologist1's Avatar
how much was that antenna
Old Sep 9, 2002 | 07:37 AM
RED_October94LS's Avatar
Default Re: antenna install (vtecnologist1)
Old Sep 15, 2002 | 11:36 PM
okay..i've decided with the insight install. thanks for all the suggestions. Is there anything else i need to get besides the antenna unit from honda? wiring? thanks in advance
Old Sep 16, 2002 | 05:20 AM
chidoks's Avatar
wow...thats a pretty neat antenna...how much did it cost? how do i contact the guy u got it from? u stole my idea for your teg.. j/k... i have a red '94 teg too... and i was going to go with an s2000 antenna and the all red tail lights too
Old Sep 16, 2002 | 10:07 PM
MugenCivic's Avatar
Default Re: antenna install (chidoks)
http://www.bseries.net/html/garage/s2kantenna.php try this its really easy
slowdc123
May 26, 2010 03:40 PM
ex voto
Aug 14, 2006 09:48 AM
Toda Built
Mar 30, 2003 07:59 PM
Andrea_Aunie
Jan 27, 2003 10:17 PM
turbopyitr
Oct 22, 2001 01:36 PM
