suspension setups
Old Sep 3, 2002 | 02:21 PM
95integrags-r's Avatar
Default suspension setups
what type of setups do you have(sway bars, strut bars, LSD, struts, springs/coilovers)
I am planning on suspension techniques front and back sway bars, (no brand chosen yet) front and back tower struts, ground controls and tokico illumina adjustible gas shocks. (lower tie bar isnt a big help is it???). oh yea and maybe a long way down the road an LSD from someone.
later
-chris wagner
Old Sep 3, 2002 | 02:23 PM
Dirty GS-R's Avatar
New User
Default Re: suspension setups (95integrags-r)
Check my sig...
Old Sep 3, 2002 | 02:34 PM
battyx's Avatar
Default Re: suspension setups (Dirty GS-R)
I have H&R race springs, Neuspeed blue's, and ST swaybars. I handled pretty damn well. You're set-up should do well too.
Old Sep 3, 2002 | 02:37 PM
Cone's Avatar
Check my sig...
Old Sep 3, 2002 | 03:08 PM
Default Re: suspension setups (Stealth 95 GS-R)
I will probably go with the carbing strut tower bars.
Old Sep 3, 2002 | 03:10 PM
wuhungsixxx's Avatar
New User
only KOni yellow and H&R race...very pleased
Old Sep 3, 2002 | 03:11 PM
Shingoblade-GSR's Avatar
Default Re: suspension setups (wuhungsixxx)
See sig...Ground Control + Koni yellow
Shingo
Old Sep 3, 2002 | 05:20 PM
GSRaCeRbOI's Avatar
I've got Eibach sportline springs, Koni yellow shocks, Suspension Techniques sway/anti-sway bars, Neuspeed upper strut tower bars and DC Sports rear lower tie bar, 16" SSR's and Dunlop SP9000 tires all around.. I my setup
Lolz do my ghetto washer/rear camber correction mods count? j/p..
on my otha car I have a similar setup.. Eibach sportlines, Koni Yellows, DC Sports front upper strut bar (yes I know), hondasport rear upper and lower bars, 16" 5Zigen's..must get new tires
[Modified by GSRaCeRbOI, 6:28 PM 9/3/2002]
Old Sep 3, 2002 | 05:26 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: suspension setups (GSRaCeRbOI)
skunk2 coilovers and camber kit, koni yellows
Old Sep 3, 2002 | 05:28 PM
vwong's Avatar
TEIN TypeHA coilovers (w/ custom rear spring rate), ITR f&r strut tower bars, Tanabe Sustec f&r lower braces, and Neuspeed 19mm rear swaybar. Oh...and 16x7 SE37K on 215/45 Azenis. Pretty good, but not enough. I will go with a 24mm rear swaybar later this year.
Old Sep 3, 2002 | 11:34 PM
Default Re: suspension setups (vwong)
does n e one knwo like the comparison of the nuespeed sways vs suspention techniques??
thanks
-chris
Old Sep 4, 2002 | 01:21 AM
abarang's Avatar
"I felt like putting a bullet between the eyes of every panda that wouldn't screw to save it's species. I wanted to open oil valves on tankers and smother all those French bitches I would never see. I wanted to breathe smoke.I felt like destroying something beautiful" -Fight Club
beaches.
Old Sep 4, 2002 | 06:55 AM
Default Re: suspension setups (abarang)
thanks
Old Sep 4, 2002 | 06:57 AM
battyx's Avatar
If I remember, ST swaybars are bigger diameter. Not by much, but w/ the cheaper price, I opted to get them.
Old Sep 4, 2002 | 06:45 PM
mikecel79's Avatar
I've got Skunk2 coilovers, KYB AGXs, ITR rear sway, and a GSR front strut bar. Car is somewhat stiff but handles just great. I heard replacing your bishings with Poly bushings makes the suspension very tight but I don't have any experience with them.
Old Sep 5, 2002 | 07:50 AM
10K2HVN's Avatar
-does ST also have the 'tie bar - sway bar combo' for the integras???
-also, should i go Ground Control or Skunk2 coilovers?? - which is better for launch - which for the turns???
Old Sep 5, 2002 | 09:17 AM
APEX i GSR's Avatar
i have the Neuspeed coilovers with front upper, front lower, rear upper, rear lower strut bars. the only thing i hate is the way the front lower hits the JDM header & causes a harsh rattle
you can barely see the bottom of the coilovers & the rear tie bar
Old Sep 7, 2002 | 12:31 AM
Default Re: suspension setups (APEX i GSR)
how are KYB adjustible shocks???
Old Sep 7, 2002 | 10:39 PM
ttt
Old Sep 8, 2002 | 11:54 AM
mikecel79's Avatar
Do you mean how do they adjust or how do they feel? They adjust with a little **** on the top or side of the shock. They are usually 4 or 8 settings on the ****. They can go from about stock softness to very very firm (on 4 they make my teeth rattle.)
Old Sep 8, 2002 | 10:42 PM
Default Re: suspension setups (mikecel79)
I meant more along the lines of, are they good/bad how is the ride, are they a good price, is there something better where those shouldnt be chosen. but thanks for that description haha
-chris wagner
Old Sep 8, 2002 | 10:48 PM
integra gsrt's Avatar
i have apexi coilovers on my teg and it rides like stock i would suggest these coilovers to anyone. expensive but worth it. 1400 but no sleeves
Old Sep 9, 2002 | 02:27 AM
bullz's Avatar
Default Re: suspension setups (integra gsrt)
Anyone have the TOKICO Adj Coilover Kit? LINK
[Modified by iLLestjr, 3:46 AM 9/9/2002]
Old Sep 9, 2002 | 03:31 AM
mikecel79's Avatar
I have them paired with my Skunk2 Springs (500f/400r) and they do just fine. If I leave them on 1 then they aren't stiff enough to keep the car from bouncing but on 2 they are fine. If your going to be getting Springs or Coilovers your ride is going to depend more on them than the shocks. I think I paid $340 for the KYBs. Excellent shock for the price.
Old Sep 9, 2002 | 07:00 AM
JeffNA's Avatar
