quick ls question
2.5" is probably too big unless it's really built up or has FI. I'm using a stock Type-R cat-back (2.25" mandrel bent piping) with a DC 4-2-1 header, and my gains are good for just I/H/E. 126.4 whp and 116.7 wtq on my last dyno, and that was on a hot day and with a short ram intake (aluminum heat magnet).
The GS-R header and exhaust will not fit a LS, but the Type-R parts will fit, iirc. I know the Type-R cat-back fits, but I'm not 100% sure about the header.
well I plan on atleast putting the crower 403 cams in(retainers and springs also of course) maybe some head work and high comp pistons when money permitts... What would be the best intake mani for the ls engine...
well if that is the case I will most likly just get the skunk2 exhaust...any opinions...
the thing is though I have no idea of what header to get or what would preform the best... I was thinking jg but not sure...
I no this is a stupid question but I have been wondering for a while... ok say the itr header does match up.. is it even a good choice...seeing ls have a more tq down low and not so much top end and its the oposite for the itr... and are you considering cams as a bolt on???
I like the 403s just fine. They gave me pretty good top end. I'm thinking of getting some headwork done, and if so I will go with the 404's, get them tuned and get some cam gears, and call it quits.
If you're not into all that then imo the 403s definately make a great cam
on that dyno run it was I/H/E, crower 403's, ported head, pullies, FPR and a lightend stock flywheel......
the header was restrictive with a 2" collector and the exhaust was also a restrictive 2" crush bent custom made exhaust..........
jdmekcivic2eg
Apr 23, 2002 06:22 AM
