Compression numbers........
Old Sep 8, 2002 | 01:49 PM
Doogie Howser's Avatar
Default Compression numbers........
i diD a compression test on my 1994 gsr with a 125,000 miles on it and i think they came out pretty good.
1- 200
2- 205
3- 200
4- 200
i was wondering if other people would post the compression numbers from there b18c1, also what year and mileage the car is
Old Sep 8, 2002 | 01:56 PM
aznmc16's Avatar
Default Re: Compression numbers........ (mlambrecht)
how did you perform the test??
Old Sep 8, 2002 | 02:38 PM
Default Re: Compression numbers........ (aznmc16)
took out all the spark plugs, took of the 15a fuel fuse, then took the compression tester and screwed it into each cylinder, and each time i put it in the cylinder i started (cranked it over) 6 times each cylinder. then after each cylinder i let the air out of the comp. tester
Old Sep 8, 2002 | 05:53 PM
Anthony K's Avatar
New User
Numbers look excellent to me.
Old Sep 15, 2002 | 08:02 AM
TimoneX's Avatar
New User
...and you tested at WOT? I assume so, since your #s are right where they belong. The testers vary so much it's difficult to compare #s from different units...plus noone ever mentions their engine temp, this will change the #s also. Neway mine came out ranging from 187-192, with the engine slightly warm.('96 GS-R)
Old Sep 15, 2002 | 05:26 PM
Westrock2000's Avatar
Default Re: Compression numbers........ (jd_healy)
it dose not matter how high they r as long as they r about the same
Brandon Peters
Oct 18, 2015 05:37 PM
xtremsiege2
May 9, 2008 09:00 AM
wutangben
Jun 2, 2003 06:21 PM
Audipwr1
Nov 16, 2001 08:42 PM
nugget8000
Aug 13, 2001 09:51 AM
