Maint. Required Light
Old Sep 10, 2002 | 08:43 AM
NeoGSR's Avatar
Default Maint. Required Light
My car just rolled over to 75,000 and now everytime I start the car, the little "Maint.Req." light blinks for about five seconds and then shuts off. I was wondering what this is and if I need to have it checked out or if there is just a little reset switch somewhere I can push.
Old Sep 10, 2002 | 08:48 AM
drewspeed's Avatar
Default Re: Maint. Required Light (killerlime)
It will go off at predetermined mileage points. If you get regular maintenance done then this light is just an added reminder. To turn it off, or reset it reach down under the steering wheel on the right hand side of the dash and there is a reset button located there.
Old Sep 10, 2002 | 08:52 AM
JMX's Avatar
JMX
Default Re: Maint. Required Light (drewspeed)
all u have to do is find the reset button under the steering column (in that area) hold it in for around 10 seconds and the light goes out....and every time it comes on just do the same thing
Old Sep 10, 2002 | 11:27 AM
niteboyzzz's Avatar
Default Re: Maint. Required Light (jmx2323)
yep, just start the car on position I or II, and hold it there until it shuts, that should reset it. But after all, if you haven't done any tune ups, you should pay attention to that light...
Old Sep 10, 2002 | 01:40 PM
iH8RICERZ's Avatar
if you get underneath the steering column, the button is blue.....all your problems will be solved!
Old Sep 10, 2002 | 02:18 PM
EJ8 Kenobi's Avatar
Default Re: Maint. Required Light (iH8RICERZ)
or you can just feel around for it..
isn't it square?
Old Sep 11, 2002 | 07:06 AM
NeoGSR's Avatar
Default Re: Maint. Required Light (FrankGSR)
Thanks for the info.....I'm planning on having the timing belt and the waterpump replaced pretty soon as preventitive maintenence.
Old Sep 11, 2002 | 07:22 AM
backlash's Avatar
I thought it was round.
96AcurategGSR
Nov 23, 2006 07:41 PM
01ITR-1268
Jun 3, 2005 09:02 PM
Curt941
Jun 27, 2004 05:25 AM
Tiwe
Jan 8, 2003 07:09 PM
Audio28
Nov 17, 2002 09:56 AM
