throw out bearing maybe???
im having problems with my clutch. i just got it like 2 months ago. i think something is wrong with the throw out bearing. (from what i understand the throw out bearing is the thing that disengages and engages your clutch) like when engaging the clutch it grabs at the very bottom. i am also having some trouble getting it in to first gear because i dont think its disengaging all the way. any advice will be greatly appreciated.
Re: throw out bearing maybe??? (vteg)
yea i checked the clutch master cylinder and its dry. they guy at autozone said that either the slave or clutch master cylinder is leaking somewhere. i havent had anytime to search for the leak yet im gonna do that on monday. does anyone know how to bleed it?
New User
Re: throw out bearing maybe??? (lsteggy)
Put fluid in the reservoir. Have someone pump the clutch. After a few pumps hold it in, while you open the bleeder on the slave. Close bleeder, and continue pumping. Repeat 5-15 times until the clutch is actuated when the pedal is pressed. You can also use one on the vacuum pump things if you have one.
so i blead the clutch. it fixed the problem the only thing is i didnt find a leak anywhere. i dont see how it could just go dry in a day or two.
nsimov
11-28-2005 08:04 PM
