rearview mirror problem
Old Dec 8, 2002 | 10:30 AM
shovell's Avatar
Default rearview mirror problem
One of my friends knocked it off and i have no clue how to put it back, anyone know?
Old Dec 8, 2002 | 11:31 AM
garados's Avatar
Default Re: rearview mirror problem (shovell)
Go to pepboys or autozone and ask for the glue to attach the mirror to the windshield. It's some wierd, two tube, epoxy stuff that works pretty well. HTH
Old Dec 8, 2002 | 01:29 PM
shovell's Avatar
Default Re: rearview mirror problem (garados)
^ actually it screws into the roof, i figured it out. But i see you have a sedan, is it different?
Old Dec 8, 2002 | 03:55 PM
GSRaCeRbOI's Avatar
which part exactly is broken or off? if I recall correctly.. the rearview mirror support/mount (not sure what its called) is mounted on the headliner by 3 screws in a triangular arrangement... the screws are covered by a plastic plate/panel which you can pry off w/ a screwdriver.. you might want to put a cloth or wrap duct tape around the screwdriver tip so you don't scratch the cover (if you care)...
or are you talking about the physical mirror part.. that came off the pivot/ball joint? if its the latter I assume you can press hard to snap it back in.. since your friend probably knocked it hard and it came off...
if its the first (the mount/screws) not sure if the mount/plastic is broken.. or if the screws are stripped at this point.. in 7 years of ownership and having lots of passengers in my car.. I've never had my rearview mirror knocked off.. but I have taken it off/apart before to try and make it stiffer so it doesn't move/change position when the subs hit...
mrbaseball13
Jan 26, 2014 11:44 PM
psudo-si
Apr 2, 2010 09:47 PM
CeoStatus0
Aug 25, 2007 11:48 PM
SpiceyRice
30
Feb 22, 2006 11:55 AM
2ndName
Dec 16, 2005 10:25 PM
