A test for VTEC!!!
Old Dec 11, 2002 | 07:38 PM
skunkintegra's Avatar
Default A test for VTEC!!!
does anyone know what i can do to test, and make sure that the VTEC is operational!
my gsr is stock...so i know i will not hear or feel vtec that much...I just want to be sure all is working since i cant hear jack!!...at times i can feel its presence..
But anyway...
can i test the solenoid for voltage or something?
i don't know where the vtec solenoid is located, so anyone with suggestions..please be detailed...
Thanks and much appreciation!!
[Modified by skunkintegra, 10:40 PM 12/11/2002]
Old Dec 11, 2002 | 07:41 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: A test for VTEC!!! (skunkintegra)
if you have a GSR, you can't really hear it.
Old Dec 11, 2002 | 07:42 PM
andrewM's Avatar
if ur still acclerating quickly and ur in the range of 4400-8000 rpm then vtec is working. on a stock gsr u cant tell when vtec kicks in, u would know if it wasnt working though.
sorry i dont i know how to test the solenoid voltage.
Old Dec 11, 2002 | 07:46 PM
Default Re: A test for VTEC!!! (andrewM)
hey....thats cool!!
yea...it pulls good in high rpm's...sounds like i am OK!
well i think know vtec is working...
the other day i worked a 2000+ de-bagded VW-lowered/exhaust, I kept losing him with each upshift
i love it
and as far as hearing VTEC....guess I've been watching too much of Skunk2nR's video of dyno day!!!!!!
[Modified by skunkintegra, 6:40 AM 12/12/2002]
Old Dec 11, 2002 | 07:50 PM
Forgiven's Avatar
Take the top off of your air box, sounds pretty loud, should be able to hear vtec then.
Old Dec 11, 2002 | 07:52 PM
gsr96's Avatar
Default Re: A test for VTEC!!! (DC4TEG)
If vtec is not operating properly or operating at all your check engine light would be on.
Old Dec 11, 2002 | 07:53 PM
fmfkid250's Avatar
wouldent that be your secondary intake that would be loud...thats what i heard when i had a b18c1
H22 much differnt
Old Dec 11, 2002 | 09:09 PM
gsxr's Avatar
Default Re: A test for VTEC!!! (fmfkid250)
unbolt the two bolts that connect to your muffler, just unbolt off....make a couple runs and git back to us....you'll hear vtec clearly
Old Dec 11, 2002 | 09:37 PM
Brasspremier's Avatar
i read in an article once that the gt-r's vtec is unnoticable
Old Dec 11, 2002 | 09:52 PM
Default Re: A test for VTEC!!! (Brasspremier)
you mean GSR, and yes, that is correct.
Old Dec 11, 2002 | 10:42 PM
KStuned's Avatar
Default Re: A test for VTEC!!! (dLo GSR)
If you wanna test for VTEC you will need: a multimeter, wire tap, and a length of wire.
Just tap into your VTEC solenoid wire: A4, then run a wire from there to one of the leads on your multimeter (or volt ohmmeter) and touch the other lead to your chassis to ground it out. Now at 4400 RPM's you should see voltage jump up and stay up until you let off the throttle! That will at least tell you for sure that your ecu is sending the signal.
Old Dec 12, 2002 | 12:50 AM
95integragsr1984's Avatar
man you cant hear vtec. lol. when i first bought my gsr after i had my ls integra i could definitly tell when the secondaries opened,4400 is a lil hard but at 5800 you should feel and hear a difference even as stock. get a aem short ram or cold air intake you will hear it. after that you'll be hooked and buy more and more **** for your car and be broke just like me.
Old Dec 12, 2002 | 12:51 AM
you lost to a 2000 jetta?? or a passat. damn, sucks if you lost to a jetta, get some mods on there.
Old Dec 12, 2002 | 01:30 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: A test for VTEC!!! (95integragsr1984)
it sounds like this....baaaaaaaaaa bAAAAAAAAAAAAAAAAA!!!!!!
Old Dec 12, 2002 | 03:41 AM
no...i was ahead the whole time....each time i would upshift...i'd lose him even more!!!
Old Dec 12, 2002 | 05:05 AM
gsr squirrel's Avatar
New User
like everyone else said on a stock gs-r you can't really hear vtec. but as soon as you add an aftermarket header it becomes much more noticable.
Old Dec 12, 2002 | 07:27 AM
NeoGSR's Avatar
Default Re: A test for VTEC!!! (gsr squirrel)
before i had a short ram intake, i took the top cover off my airbox and it made it sound alot better and the filter was still doing its job....w/ just an intake, if you listen really close, you can hear the x-over at 4,400....
Old Dec 12, 2002 | 11:30 AM
DR3AM's Avatar
Default Re: A test for VTEC!!! (CiRcUiTsi)
ROFl...
Actually, it does!!!
Old Dec 12, 2002 | 07:44 PM
GSR's Avatar
GSR
Banned
yea u could test it like that or buy a AEM intake
Old Dec 12, 2002 | 07:48 PM
B00ST2nR's Avatar
Default Re: A test for VTEC!!! (GSR)
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Here's my stock GS-R, and I can hear the Vtec kicking in clearly.
[Modified by Skunk2nR, 8:48 PM 12/12/2002]
Old Dec 12, 2002 | 07:55 PM
Buckshot's Avatar
Default Re: A test for VTEC!!! (Skunk2nR)
trust me u can feel the diff when vtec is working...
a lil while ago my thermostat was stuck wide open so my engine wouldnt fully warm up therefore vtec did not work..
it was so god damn slow, the diff was quite noticable
Old Dec 12, 2002 | 08:12 PM
threatcon13's Avatar
New User
Default Re: A test for VTEC!!! (Buckshot)
my car's vtec when i only had an injen short ram sounded as loud as itr cams. but 130 bucks is an expensive solution. use the multimeter.
Old Dec 13, 2002 | 06:47 AM
four27's Avatar
Default Re: A test for VTEC!!! (ALLMOTORDC2)
my VTEC is obvious to me and I have a 40% hearing loss. You should hear it and feel it. Remember you need over 50lbs of oil pressure for it to work so confirm you have good oil pressure.
Old Dec 13, 2002 | 12:56 PM
Red!ine's Avatar
Nice vid, I busted a nut when VTEC engaged. That **** was loud!
Old Dec 13, 2002 | 01:01 PM
New User
Default Re: A test for VTEC!!! (kAoTiK)
haha..then youll faint when you hear vtec engage on a b18c5 equipped w/ JUN 3s screaming to 9000 rpm.
