E-brake HELP!
Old Dec 11, 2002 | 11:44 AM
gsr96's Avatar
Default E-brake HELP!
alright, I went to school this morning and when I parked I pulled my e-brake like I always do. But, when I pulled it it did not click. I let it go and it fell back down. The parking brake does apply when I pull it up though, it just won't stay up. For now, its propped up wiht my cell phone. Anybody had this problem or know whats wrong?
Old Dec 11, 2002 | 11:52 AM
nek0's Avatar
Default Re: E-brake HELP! (gsr96)
the e-brake cable is broken?
Old Dec 11, 2002 | 12:18 PM
El colombiano's Avatar
yeap lift up ur carpet and look where the ebrake is behind is i where the cable are running in mostl likely one or both are broken
Old Dec 11, 2002 | 12:34 PM
Paste's Avatar
Loved
Default Re: E-brake HELP! (El colombiano)
but FYI you can park your car in gear, it will probably work better than a ghetto rigged ebrake.
Old Dec 11, 2002 | 07:28 PM
gsr96's Avatar
If the cable was broken, then the brake would not hold at all, correct?
Old Dec 11, 2002 | 07:41 PM
robhamaliuk's Avatar
Default Re: E-brake HELP! (paste)
thats true, but ur car can slip out of gear, while an ebrake in working order shouldn't
Old Dec 11, 2002 | 08:02 PM
Forgiven's Avatar
Mine does that occasionally, I just pull the e-brake a little ways up and flip the button. Catches every time. The button that locks the e-brake is just getting stuck, no big deal, as long as you can feel the tension from the brake that you normally do, then it's just the button getting stuck.
[Modified by DC4TEG, 5:05 AM 12/12/2002]
imadigitalgod
Jan 5, 2010 01:23 PM
t_mac
Jan 13, 2009 01:13 AM
ONEhaque
Nov 10, 2008 06:23 PM
thebinaryman
Dec 4, 2007 05:23 PM
coupe_hybrid
May 19, 2006 08:06 AM
