abs problem..
Old Dec 9, 2002 | 08:10 PM
94tegAddict's Avatar
Default abs problem..
my abs is not working. there is nothing leaking underneath the abs module, so i guess the ring is still intact, but the fluid level is at minimum. it could be other problems too, but first thing first.
-can anyone provide some info about how to add the abs fluid? step by step instruction in plain english if possible.
-if i take it to dealer, how much am i looking at?
-what could be other possible causes?
pretty stressful looking at that abs light all the time.. thanks for any info..
Old Dec 10, 2002 | 03:52 AM
EVOTHIS's Avatar
Default Re: abs problem.. (94tegAddict)
can you pull the code?
I work in service at Acura and can tell you what is wrong with it.
To add fluid just take off the grey cap and use a small screwdriver to un-plug the plastic stopper.
Old Dec 10, 2002 | 05:27 AM
Default Re: abs problem.. (b18c ya)
uhm.. i never encountered problem with the car until this date.
how do i pull the code?
isn't the abs fluid highly pressurized?
Old Dec 11, 2002 | 12:18 AM
jpaik's Avatar
you can find out the cel or abs code thrown by following the directions here: http://www.c-speedracing.com/faq/06.php. as for the codes, i don't know where to find those.
i have a problem with my abs as well, most likely a pinched line from the rear strut install. if anyone could let me know what abs code 17 and 81 are, i'd appreciate it.
TIA
civicexowner
May 14, 2009 03:04 PM
rhd
Nov 10, 2005 06:25 PM
seeeker
May 23, 2005 12:31 AM
social_control
May 23, 2003 06:27 AM
