compression test?! what should the compression be?
Old Feb 10, 2003 | 11:54 AM
Triple T's Avatar
Default compression test?! what should the compression be?
Anyone know what the reading for an ls block with type r pistons should be? does 220 across all 4 sound about right?
Old Feb 10, 2003 | 01:12 PM
Typiko512's Avatar
Default Re: compression test?! what should the compression be? (triplet)
as long as the differences between each cylinder is between 5~10 no more than that. If it's over, then rings/pistonz causing it
Old Feb 10, 2003 | 01:42 PM
Eva01's Avatar
220 across all pistons is awsome. Sounds like you have a very healthy motor.
Old Feb 10, 2003 | 01:56 PM
maxxdout's Avatar
Default Re: compression test?! what should the compression be? (Eva01)
be more concerned with a leakdown test.
Old Feb 10, 2003 | 03:23 PM
DR3AM's Avatar
Default Re: compression test?! what should the compression be? (maxxdout)
Old Feb 10, 2003 | 03:32 PM
Triple T's Avatar
Default Re: compression test?! what should the compression be? (Gizzzer98)
what should the readings for a leakdown test be? what are somethings i should look for?
crazyhouse2011
Mar 18, 2013 07:50 PM
92vxjdm
Aug 15, 2008 05:05 AM
Got_soy
28
Aug 8, 2005 12:49 PM
gsr~hatch
Apr 17, 2003 03:19 PM
