oil filter?
Old Feb 7, 2003 | 06:29 PM
sharkey65a's Avatar
Default oil filter?
hey i know this is a retarded question but where is my oil filter and how is the best way of getting to it?
Old Feb 7, 2003 | 06:38 PM
stegs's Avatar
Default Re: oil filter? (sharkey65a)
back of motor between firewall and block. put car on jackstand to get to it. really helps if you have the appropriate wrench to fit. Don't fool around, use only honda filters with flowback valve. around 5 bucks @ A&hmotorsports.com
Old Feb 7, 2003 | 06:42 PM
(__________)'s Avatar
Default Re: oil filter? (stegs)
jack the car up and lay underneath you engine and look up the back of the block, cant miss it
Old Feb 7, 2003 | 06:44 PM
ragejed's Avatar
So you are sayin that using Mobil 1 oil filters is bad?
Old Feb 7, 2003 | 06:47 PM
stegs's Avatar
Default Re: oil filter? (ragejed)
nah just that its to $$$$$$$$ for same quality as oem
Old Feb 7, 2003 | 06:54 PM
sharkey65a's Avatar
aight all my oils out and its jacked and im sitting under the filter.. how the hell do i get that thing out?
nevermind ive figured it out,
thanks everybody..
[Modified by sharkey65a, 3:58 AM 2/8/2003]
Old Feb 7, 2003 | 06:58 PM
stegs's Avatar
Unless you do mucho forearm reps then it can be tuff without a wrench.
you can always poke a screwdriver through it to get extra leverage...messy thou
Old Feb 12, 2003 | 03:21 PM
iam7head's Avatar
just buy a wrap-around wrench at autozone=2.99
I just have my oil changed 15 min. ago.
dont forget to lude the new filter and get a new washer for the drain bolt
Old Feb 12, 2003 | 03:22 PM
iam7head's Avatar
Default Re: oil filter? (iam7head)
stupid *** shop give me a wrong size washer
Old Feb 12, 2003 | 04:22 PM
tC_Dragon's Avatar
just for future reference... this is the BEST tool i think for filter removal.. makes it a hundred times easier.. thanks to the guys here at ht i picked one up at sears and ask my roomate.. it made it 100 times easier... oh and for the drain bolt, i actually replaced mine with one of those fram sure drain things.. so all i have to do is screw on a hose to the new replacement drain bolt and put the other end of the hose in my drain pan and i get zero mess.
here's a pic of the craftsmen oil filter removal tool i was talkin bout...
here's the sure drain thing...
[Modified by pdcdragon, 5:26 PM 2/12/2003]
Old Feb 12, 2003 | 04:53 PM
ejprimo's Avatar
how are u so sure that oem "fram" or "filtech" oil filters are of the same quality as mobil 1?
Old Feb 12, 2003 | 05:23 PM
PandaBear's Avatar
Default Re: oil filter? (ejprimo)
People have cut it open before, M1 has much finer filter media.
To be honest I think you can just use anything but Fram, Purolator Pure 1, Wix, Champion are all good for <$4
Old Feb 12, 2003 | 05:51 PM
ejprimo's Avatar
Default Re: oil filter? (PandaBear)
yup, just stay away from any fram oil filter: honda oem "made in canada", pennzoil oil filter, defense oil filter. also try to saty away from some of the lower-end purolator oil filters that also uses cardboard endcaps.
Old Feb 12, 2003 | 06:02 PM
Honda Hick's Avatar
whats your reasoning for staying away from FRAM?
Old Feb 12, 2003 | 07:13 PM
ejprimo's Avatar
Default Re: oil filter? (Honda Hick)
1. cardboard endcaps- i sure dont want any cardboard breaking off and circulating in my motor.
2. plastic bypaass valve- these valves are prone to breaking which will cause your filter to stay in bypass mode all the time, i.e. oil will circulate in your motor w/o passing through the filter.
3. no or faulty anti-drain back valve- when you shut off your motor oil will flow back out of the filter leaving it with no oil which leads to dry start-ups.
Old Feb 12, 2003 | 10:04 PM
GSRaCeRbOI's Avatar
speaking of cutting open filters and examining whats inside.. just in case you guys/girls haven't seen this link..
http://www.ntpog.org/reviews/filters/filters.shtml
Old Feb 13, 2003 | 04:20 AM
JimBlake's Avatar
Default Re: oil filter? (pdcdragon)
What?? All the mess comes from the filter, not the drain! Why did they put the filter back there so it HAS to spill all over the axle & the exhaust pipe?
Old Feb 13, 2003 | 04:23 AM
tC_Dragon's Avatar
Default Re: oil filter? (JimBlake)
well i let my oil pan drain as much as possible before removing the filter, and i also open up the oil cap obviously, so there is no pressure holdin it in, and tap on the oil filter a little to help get the oil out of there.... then i put some papertowels underneathe where the filter is, up on part of the block, and then remove the filter, the towels soak up all the oil and no mess. i swear i had one maybe two small drops of oil on teh floor the last time i did an oil change and they were maybe 2.5" in diameter... thats bout it.
namewasdallas
Jun 2, 2010 08:48 AM
asubennett
Apr 13, 2006 04:06 PM
TeGGY_LS
Aug 6, 2004 01:16 PM
EKB18BPR3
Aug 18, 2002 02:43 PM
