Problems: Rough starts...
Old Feb 10, 2003 | 09:45 AM
-BlueGSR-'s Avatar
Default Problems: Rough starts...
My car recently has been having a hard time starting...usually on very cold days...or when the fuel is low...which i know is normal....but lately its been happening more...and taking longer to actually turn over.....what could be the prob?....fuel filter??..anything else?
Old Feb 10, 2003 | 10:36 AM
Eva01's Avatar
Default Re: Problems: Rough starts... (GS-ssbp-R)
Starting always takes a bit longer when the fuel is low...this is normal. Not sure about the cold weather thing.
Old Feb 10, 2003 | 10:38 AM
NeoGSR's Avatar
Default Re: Problems: Rough starts... (Eva01)
it was -15 in alex today and it took my car a while to get chugging too....i always try to keep my car above a half tank when it's really cold out, also, it's a good idea to put a bottle of iso-heet in when it's really cold out and it sits outside overnight....keeps gas lines from freezing and the heet will burn the water out too...
winter sux!!!!
Old Feb 10, 2003 | 10:44 AM
4doorRS5spd's Avatar
New User
Default Re: Problems: Rough starts... (NeoGSR)
What weight motor oil are you using in that minus 15 degree weather? Just thought I'd ask. Also, turn the key to the "on" position before you crank it all the way. This will allow the fuel pump to go ahead and wake up, so to speak, and begin delivering fuel. Wait a couple of seconds and then try to crank. It should help. My car does this on cold days as well. It's perfectly normal as was said above.
Old Feb 10, 2003 | 10:46 AM
NeoGSR's Avatar
Default Re: Problems: Rough starts... (4doorRS5spd)
5w-30
i don't really dare to go any lighter w/ 85,000 miles and the way i drive
i let it warm up for about 10 mins before even touching the gas
i do put my key to "On" for a couple of secs to let the fuel pump "wake up", it seems to help a little bit....
Old Feb 10, 2003 | 10:54 AM
New User
Cool. I just wondered about the oil. I use 10W-30, but I live in NC, where it rarely gets colder than the 20's and is usually in the low 40's to high 50's all winter. I knew though, that the 5W-30 was better in colder temps. Thanks.
Old Feb 10, 2003 | 10:57 AM
NeoGSR's Avatar
ya, running 10w30 in that weather should be no problem, i might run that in the summer
Old Feb 11, 2003 | 09:53 AM
EvilIntegrationLS's Avatar
yea, i run 10w30 and i live in atlanta, GA and my car has serious mileage, but no problems with the oil. but i've had the similar problem with a slow start sometimes when it gets a little cold outside.
Phailzilla
Jan 18, 2014 11:13 AM
Ron Burgandy
Jan 8, 2012 07:01 PM
dudeomega2000
Jul 13, 2009 08:15 PM
davidluko
Oct 8, 2006 10:22 PM
brockscivic
Jul 23, 2004 04:56 AM
