Compression
Old Apr 16, 2003 | 10:06 PM
gsr~hatch's Avatar
Default Compression
I am buying a 1997 gsr motor and the compression is 180dry, and 210wet. What is the difference between the two, and what should a good compression be for this motor? I am getting it tested in the morning and need to know what to look for. Thanks in advance James
Old Apr 17, 2003 | 01:41 AM
MikeSarr_GSR's Avatar
Default Re: Compression (g2integ)
that is normal for 10:1
Old Apr 17, 2003 | 07:51 AM
B U N M A N G O's Avatar
Default Re: Compression (MikeSarr_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">that is normal for 10:1</TD></TR></TABLE>
really? I thought most GSR owners are reporting 210-215 dry, consistent across all the cylinders? I did a test a few weeks ago, got something like 185, 180, 155, 160 for my dry test, then 210's with a wet test. Helloooooooooo new piston rings?
Old Apr 17, 2003 | 09:02 AM
tilt's Avatar
sounds normal to me. i tested between 210-220 with the engine warmed up.
Old Apr 17, 2003 | 09:17 AM
correct me if I'm wrong, but a dry test = just a normal compression test, and a wet test = adding a capful of oil into the cylinder before you do a compression test? Something about sealing the piston rings temporarily if they're worn?
Old Apr 17, 2003 | 09:26 AM
IN VTEC's Avatar
Default Re: Compression (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">sounds normal to me. i tested between 210-220 with the engine warmed up.</TD></TR></TABLE>
Same.
220psi all across on mine with 75k miles
220psi all across on my friend's GS-R with 98k miles
Both were warm and followed proper standardized compression test procedure with a Sears Craftsman gauge.
Old Apr 17, 2003 | 03:19 PM
mickey513's Avatar
Default Re: Compression (IN VTEC)
I got 220+/- a few on all 4 cylinders on my 94gsr with 120k miles.
jdmcivic2fast
Oct 2, 2011 08:19 PM
humboldt_skim
May 31, 2008 08:18 AM
godnf8
Feb 12, 2007 07:33 AM
Got_soy
28
Aug 8, 2005 12:49 PM
lazyguy
May 5, 2002 01:36 PM
