b20a bolt on?
Old Apr 16, 2003 | 11:14 PM
UberTeg's Avatar
Default b20a bolt on?
Will a b20a (from old skool preludes) bolt into my teg? Plz dont try to school me on r/s ratios, just stay on topic. Thx I mainly want to know if my teg tranny will bolt up, and whether i can bolt my teggy head (non-vtec) on the b20a block.
Old Apr 17, 2003 | 10:41 AM
UberTeg's Avatar
Default Re: b20a bolt on? (UberTeg)
bump
Old Apr 17, 2003 | 12:19 PM
UberTeg's Avatar
I kno someone knows if the motor will bolt up... are the bell housings the same?
Old Apr 27, 2003 | 09:49 PM
JDMs1eeper's Avatar
B20a's are cheap as hell and u see them in all the junk yards... let us know what happens!
Think u can use the crank from the B20a in a B18a/b or B20b/z to stroke them? think it would work?? that would be bad @$$
Old Apr 27, 2003 | 09:54 PM
GSR Dave2094's Avatar
Default Re: b20a bolt on? (Typesi2nv)
i really don't see the point in putting an LS head on a B20 block jsut for a little extra torque. It's not worth it. If you're gonna drop in a B20 block in your Teg, then swap on a VTEC head and jsut go B20 VTEC. It's an expensive swap but well worth it. Either that or jsut put on a Turbo to your LS motor. It's not worth the time and $$ to put an LS head on a B20 block for a little extra torque. NAd yes you can use your Teg tranny. All teg's ('90 and up) have B series motors and B series motors can bolt to any B series tranny.
Good Luck!!
Old Apr 27, 2003 | 10:25 PM
E-Rok's Avatar
EPIC TUNING
Default Re: b20a bolt on? (GSR Dave2094)
he is talking about the old prelude B20 which was actually a major POS and it doesnt bolt in anyways....
Old May 1, 2003 | 11:37 PM
Westrock2000's Avatar
Default Re: b20a bolt on? (SlprTeg)
Ya I believe the older B20A is actually more along the lines of the A20 or whatever from the 87-89 Accords or whatever. I am almost sure that it will not go in.
Old May 2, 2003 | 03:04 AM
10K2HVN's Avatar
Default Re: b20a bolt on? (Westrock2000)
i believe the B20A is the one with a 95mm crank that fits the newer B-series motors.. You can make any B-series 2.0 litters with a 82mm bore!
Old May 2, 2003 | 03:25 AM
Davanca's Avatar
Default Re: b20a bolt on? (10K2HVN)
That motor will go in your teg. The only prob is that, that is a single overhead cam motor. So if your thinking about putting your LS head on that block you can forget it. I never heard of a DOHC head on a SOHC block.
jscrib
Sep 6, 2011 02:46 AM
stratedrm
Aug 8, 2007 09:31 AM
akkord94
Nov 15, 2003 10:47 AM
civicHBphatride
Sep 28, 2002 11:50 AM
