Hops
Old Apr 15, 2003 | 08:56 PM
TegLover4life
Guest
Posts: n/a
Default Hops
My clutch feels really funny under my foot when i shift. Also it is hard for me to put it into gear sometimes. After i drive around for a little bit, once i try to start the car kind of hops and shakes until i get going fast enough. Any ideas?
Old Apr 16, 2003 | 05:40 AM
Evilteg's Avatar
Default Re: Hops (TegLover4life)
my buddy girl down shifted once without reving the engine up properly and popped a load spring on the clutch, not letting her shift into gear when the car was driven for a short distance. did someone not downshift right??
Old Apr 16, 2003 | 05:59 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegLover4life &raquo;</TD></TR><TR><TD CLASS="quote">My clutch feels really funny under my foot when i shift...</TD></TR></TABLE>
Describe the funny feeling. Does it engage close to the floor or at the proper height? What year (is it a hydraulic clutch)? It might be as simple as needing to bleed air out of the clutch system or even sloppy hinges on the pedal itself.
Old Apr 16, 2003 | 05:35 PM
TegLover4life
Guest
Posts: n/a
Default Re: Hops (JimBlake)
It is hard shifting at high rpms... it might have been the spring because other people drive my car when i am too drunk but idk.. how do i bleed the air out... not too great with engines
Old Apr 16, 2003 | 05:38 PM
NeoGSR's Avatar
sounds like one of the springs popped....sounds like many others with the same problem....
Old Apr 16, 2003 | 05:40 PM
NeoGSR's Avatar
new clutch
Old Apr 16, 2003 | 06:39 PM
siis2fast's Avatar
i would get a lightend flywheel. depends on what mods you have, but you really cant go wrong with a CM stage 3 and lightned flywheel. cheep and will be able to handle just about any mods you do to it. its good for about 300hp i think
Old Apr 25, 2003 | 12:19 PM
95 Gizzer
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegLover4life &raquo;</TD></TR><TR><TD CLASS="quote">It is hard shifting at high rpms... it might have been the spring because other people drive my car when i am too drunk but idk.. how do i bleed the air out... not too great with engines </TD></TR></TABLE>
Hey man dont blame me, I'm the best driver that's ever driven your car
98R-1144
Jun 27, 2008 07:40 AM
k_lude
Jun 19, 2007 08:19 AM
lokodog
Dec 25, 2005 09:39 PM
All Motor Ek99
Apr 8, 2005 06:51 AM
faultofhumanity
30
Sep 13, 2003 10:47 PM
