Running a test pipe on an obd2 gsr
Old Apr 17, 2003 | 10:30 PM
Brett's Avatar
Default Running a test pipe on an obd2 gsr
I've got a 97 gsr and I wanna put in a test pipe and not get the cel. Couldn't I simply disconnect the second o2 sensor and hook the wires to the first o2. The reason I say this is the first o2 is in the headers so that's unaffected by the cat and the second one just causes a cel if there is a difference from the first one. Just an idea, let me know what u think.
Old Apr 18, 2003 | 04:35 AM
JimBlake's Avatar
Default Re: Running a test pipe on an obd2 gsr (Brett)
I think its the other way around. If the 2 sensors read the same thing, you'll get a CEL. The catalyst 'uses up' the oxygen, so the ECM is expecting to see a difference between the 2 readings.
Old Apr 18, 2003 | 10:43 AM
LSVTEC408's Avatar
Default Re: Running a test pipe on an obd2 gsr (JimBlake)
i was running a test pipe on my 97 gsr they sell pipe with two inlets for both your sensors, but becareful not to burn the wires of one, cause thats what happen to me the sensor wires touched the testpipe which melts it when is hot, it happen and caused a big short, so be careful.
testpipe.com
Old Apr 18, 2003 | 12:56 PM
The Poopsmith's Avatar
Default Re: Running a test pipe on an obd2 gsr (LSVTEC408)
I'm running a test pipe w/ 2 o2 sensor inlets, i've been w/ no cel for about 8 months now, and it dosent look like im gonna get one.
THe only precaution I would take is being careful of not buring the wires of one of the o2 sensors like LSVTEC408 said.
mxracer420
Mar 25, 2010 04:33 PM
kantfadedisazn
Aug 3, 2009 10:00 AM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
98B18C1
Oct 6, 2004 09:39 PM
comptechgsr2000
May 9, 2002 07:36 PM
