Wiring Help needed!!!!
Hey everyone. I have a 99' Integra LS. I just got some M3 Mirrors with the lights and Indiglo Door Sills. I want the mirrors to flash with the turn signal because I think the lights staying on all of the time will get me pulled over. I need some hints on where to wire each mirro so they flash correctly(left flashes when left blinkers are on...etc). I figure running a wire to my turning lamps but that seems like a little too much work and I'm not sure of an easier way. For the Indiglo Door Sills, I want them to come on when the door opens. Where do I need to wire that to so they shut off when the doors shut.
Please write any comments, instructions, hints, or web references on how to do all of this. THANK YOU IN ADVANCE FOR YOUR HELP!!!!! I have had some good advice from this forum latey. Thanks everyone!
Don't quote me on this but check your fuses and see if there is a seperate one for the left and right, if so then just tap into that. If no then trace down the wires that come out of the 'blinker control' on the steering column: according to my haynes manual, right is green\yellow and left is green\blue.
as for your door sills
tap into the door trigers wich is (-) this will turn on when open and turn off when
closed.
(+) always constant but if you plan to keep your doors open for a while
I suggest you use a relay.
closed.
wako182774
Nov 2, 2005 10:36 PM
