diff between integra clusters...help!
Old Apr 18, 2003 | 12:11 AM
Aaron.'s Avatar
Default diff between integra clusters...help!
i swapped a 99 gsr dash into my 93 civic hatchback. i also used the teg dash harness. anyhow, i didn't have money to buy the cluster so i spliced in my old civic cluster and it was fine...now that i bought a teg cluster and wired it up, it is acting funny. i bought a 99 gsr cluster but things are going all screwy
1) high beams don't stay on unless the car is off
2) when i start the car, the arrows for turnsignals are lit (dimly)
3) turn signals don't work
4) when i turn on high beams (when car is on) the turn signal arrows light up instead of the blue high beam indicator
5) when i put on the hazards, they alternate between the high beam indicator and the turn signal arrows. also, the rpm drops to zero everytime the turn signal arrows light up.
my question is, the civic cluster worked fine, is the reason because i used a newer cluster that these things are happening? if i get a old teg cluster will it work fine again? is it because of the OBD difference? help!!! thanks.
Old Apr 18, 2003 | 12:09 PM
Aaron.'s Avatar
Default Re: diff between integra clusters...help! (Zensokuryoku)
ttt!!!
are OBD1 Clusters diff from OBD2 ones? is this causing my problem???
Old Apr 18, 2003 | 01:17 PM
CNSK's Avatar
maybe its an obd2 cluster, try 94-95 cluster.
Old Apr 18, 2003 | 02:27 PM
Aaron.'s Avatar
Default Re: diff between integra clusters...help! (DrMartin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin &raquo;</TD></TR><TR><TD CLASS="quote">maybe its an obd2 cluster, try 94-95 cluster.</TD></TR></TABLE>
so there is a difference between the different obd generation clusters? can anyone confirm this? i need help ASAP!!
Old Apr 18, 2003 | 03:43 PM
djkermie's Avatar
Yes the clusters are different.
94-97 Integra clusters use a different system than the 98-01 Integras.
Looks like you'll need to trade in your 99 cluster for a 94-97 cluster to use in your Civic.
Old Apr 18, 2003 | 06:18 PM
Aaron.'s Avatar
Default Re: diff between integra clusters...help! (djkermie)
ok good, at least i have conformation. now i gotta try find someone to swap. anyone need a 99 gsr cluster w/49k miles? its mint condition!!! argh
Old Apr 18, 2003 | 09:44 PM
CNSK's Avatar
thats something i learn on ebay, whenever a seller sells those typeR cluster, they always state 94-97 teg only 98+ may require modifications. then there some typeR cluster that only states, 98+ only. so watch out on what you buy, ebay should have plenty of clusters
Old Apr 19, 2003 | 06:23 PM
AnNiMosSiTY's Avatar
DUDE plz trade me !!!!!! that is the problem, i got a stolen 99 gsr and it had no gauge cluster and i bought a GSR cluster off ebay thinkin theyre all the same. Well they all hook up the same but i guess theyre wired differently the one i have is 94 spec with 58k miles on it. My gas gauge dont work and my lights do not come on when i hit my switch for the lights i just recently found out that they had to be matched up for the year of the car. If you would like would u be intersested in trading ill send u my phone # in a PM
Sjalabais
Honda Civic (2001 - 2005)
Jan 14, 2016 01:13 PM
Wrona
Dec 26, 2011 08:19 PM
cm8719500
Mar 31, 2008 09:28 PM
rkn527
Sep 11, 2003 08:04 PM
