da integra shift light
Old Jun 16, 2011 | 05:15 AM
slowboy90's Avatar
Default da integra shift light
i bought a proform shift light. I also have the msd pro billet setup i wire it to the empty blue wire in the msd harness and nothing happened so im trying to figure out where to wire it too
Old Jun 16, 2011 | 05:48 AM
fcm's Avatar
fcm
Old Fart
Default Re: da integra shift light
I found this... Your Proform shift light will require an adapter PN 8920. This will install in between the tach output on the MSD, and the shift light.
http://www.msdignition.com/product.a...723&terms=8920 94
Old Jun 16, 2011 | 05:03 PM
slowboy90's Avatar
is there no other way to do this and the link you posted wont open
Old Jun 17, 2011 | 05:36 AM
fcm's Avatar
fcm
Old Fart
No there is not.
Link works for me.
Go to MSD... http://www.msdignition.com/default.aspx
Click on products... http://www.msdignition.com/products/
Then on accessories... http://www.msdignition.com/products/accessories/
Then on tach adapters... http://www.msdignition.com/info.aspx...256&taxid2=267
Find and get the adapter you need. 94
Old Jun 17, 2011 | 06:20 AM
slowboy90's Avatar
thanks for the help man i email msd to ask them which one i needed as well as proform thanks for the fast replys
Old Jun 20, 2011 | 08:50 AM
slowboy90's Avatar
the tech from msd is telling me i need to hook it up to the other tach signal wire
Old Jun 20, 2011 | 01:21 PM
fcm's Avatar
fcm
Old Fart
What other tach signal wire?
Exactly what MSD equipment do you have on the car, and what is the MM&Y of car?94
Old Jun 20, 2011 | 01:56 PM
slowboy90's Avatar
its a 91 integra, converted to obd1, with an obd2 msd dizzy, sportcompact coil and the driver they said the tach wire i hooked to is messed up and use the blue wire in the main harness ill post back tonight when the new one gets here
Old Jun 20, 2011 | 04:59 PM
slowboy90's Avatar
well it worked without the tach adapter wiring to the original wire i thought had to get a better connection to it
Old Jun 20, 2011 | 05:05 PM
fcm's Avatar
fcm
Old Fart
IC, I thought you had the complete MSD system, not just the distributor and coil.
But good that you got it working. 94
Old Jun 20, 2011 | 07:13 PM
slowboy90's Avatar
its still a little jumpy but i appreciate the help and fast responses
Full Race A6
14
Jul 1, 2004 02:15 PM
Que_Lude
Feb 28, 2004 04:37 PM
mod5
Dec 22, 2003 12:56 PM
AllmotorJunkie
Jul 8, 2003 09:34 AM
