Heating issues
Old Jun 5, 2011 | 10:06 AM
Juan_95_Integra's Avatar
Default Heating issues
I just installed a turbo in my b16a and for some reason the headers are getting red hot and quick what could make it do this and what can i do to fix it. And when i first start it it idles fine and not even 2 sec later it jumps up to 3,000rpm?
I still have not hooked up my o2 sensor and Im use a chasebay wire harness if that makes anything different but everything is factory stock
Any help will be great!
Old Jun 5, 2011 | 02:01 PM
hondad6's Avatar
Default Re: Heating issues
It needs a tune it is running rich and hot. If you start running it hard the pistons and valves will melt, or the fuel will detonate prematurely and throw a rod. this is bad all around. Yes the O2 is a necessity because it determines the fuel map adjustments. The wire harness could be a problem but most likely if it is running OK then it is fine. Look into getting a chipped ecu with chrome s200 or hondata. a good place to look is, http://www.rywire.com/catalog/index.php . There is a lot that goes into successfully turbocharging a car and it lasting. The tune is most important. Also a good improvement is to go from OBD0 to OBD1.
Sorry i meant it is running lean and hot, had to edit today to get it straight.
Jdm John
Dec 25, 2009 12:29 PM
vandersmissenc
May 1, 2007 07:16 PM
turbod96ex
Apr 29, 2004 09:36 PM
civicracer1993
Feb 23, 2003 07:40 AM
LS-G
Jun 21, 2002 08:11 PM
