'94 headlight switch doesnt turn on parking lights
Odd issue. So I changed my brakes and my parking lights stopped working. Im pretty sure they are not related just funny coincidence. I have brake lights and the headlights turn on too but, the first position of the switch does nothing. Be for I go ripping the steering wheel off and replacing the switch could someone tell which wires I could jumper on the clip to test if its farther down. Its not the fuses either, there is 7.5 and a 10 amp for controlling them and the the relay for them. Also could somewhere tell me where that relay is. Thanks.
Re: '94 headlight switch doesnt turn on parking lights
i have a smilare issue with me parking lights not working but my turn signals work just fine.... with my parking lights on, only my passenger sidemarker comes on but but the other 3 dont work.
Are the parking lights on when you have the lights on? Have you checked or replaced the bulbs? Maybe pull a light switch from a junkyard and try swapping that.
Problem was the wiring was burned out that leads to the fuse box under dash. Im assuming that the wiring for my climate control is burnt too since that doesnt work either
fourblades
05-07-2015 09:18 PM
boostjunkieee
12-12-2012 05:52 PM
jArceo
02-14-2006 11:25 AM
