Coolant temp sensor ?
Old Jun 6, 2011 | 01:11 PM
jlowellintegra's Avatar
Default Coolant temp sensor ?
I think iv narrowed my heat fluctuation down to the cts because my fan stopped working...my check engine light will pop up when the heat rises and I might have smoke and the engine bay doesn't seem any hotter
So what I would like to know is where the sensor is located on a gsr? And if there hard to change/prices!
Please help me out
Old Jun 6, 2011 | 04:17 PM
Default Re: Coolant temp sensor ?
Bump
Anybody???
Old Jun 6, 2011 | 04:30 PM
pushlbs's Avatar
should be in the head near the rad hose. if not then by the t-stat. trying to rember been a while lol
Old Jun 6, 2011 | 04:34 PM
1998GsRIntegra's Avatar
Between the vtec solenoid and the distributor. Its black, one wire I believe. Good luck.
Old Jun 6, 2011 | 04:46 PM
fcm's Avatar
fcm
Old Fart
It is not the ECT sensor, it is the ECT switch, [rad fan switch] two different "units".
It is located on the thermostat housing, where lower rad hose is connected to engine.
Unplug it and jump the green and black leads, if rad fan turns on, replace the switch. 94
Old Jun 6, 2011 | 09:42 PM
JOE_DC4ever's Avatar
^ Yes
Old Jun 8, 2011 | 02:03 PM
Ok you were right it's the fan switch I have a paper clip taped in there so my fans always on.......but the temp gauge still gos up then comes down so could it just be the sensor or gauge sensor
Old Jun 8, 2011 | 04:26 PM
fcm's Avatar
fcm
Old Fart
What do you mean, "but the temp gauge still gos up then comes down"???
Up how far and down to what?
Does it go up and down constantly?
If so,^^^ bleed the coolant system.
When was the last time thermostat was changed? 94
Old Jun 8, 2011 | 10:34 PM
vtaker's Avatar
When my gauge sensor went out it would go to 1/8 past cold at a stop light, then it would hit the C when I started driving again. Just kept going back and forth.
Old Jun 9, 2011 | 11:35 AM
It will go up 3/4 the way then come down to normal temp I just changed the thermostat and opened the bleeder just liquid came out no air
Old Jun 9, 2011 | 12:14 PM
vtaker's Avatar
So is the car overheating you think? You should either get an automotive thermometer or just replace the sending unit for $14 since they do eventually go bad.
http://www.autozone.com/autozone/par...questid=980305
Old Jun 9, 2011 | 12:54 PM
I don't think it's overheating my fan is on and it doesn't feel overly hot to the touch the valve cover u can pretty much keep your hand on but it's just nerve racking to see my temp shoot up
Where is the sending unit??
Old Jun 9, 2011 | 04:30 PM
fcm's Avatar
fcm
Old Fart
Does it stay at normal once it goes there? 94
Old Jun 9, 2011 | 06:51 PM
It's stay normal when I first drive it then it will randomly go up then come back to half way and stay there usually
Old Jun 9, 2011 | 10:54 PM
vtaker's Avatar
Sounds like the sending unit then.
Its the one wire black/yel
Old Jun 10, 2011 | 04:18 AM
I don't think it's that I unplugged it and the check engine light came on so its working right???
Old Jun 10, 2011 | 05:33 AM
fcm's Avatar
fcm
Old Fart
Actually it's the yellow/green one wire sensor.94
Old Jun 10, 2011 | 05:48 AM
Would you KNOW if the car was overheating by opening the hood??? I can keep my hand on the valve cover and the radiator hoses they aren't really hot
Old Jun 10, 2011 | 07:29 AM
fcm's Avatar
fcm
Old Fart
If you can keep your hand on the rad hoses. it's a good bet your not overheating.
A thermo gun is the best way to be sure.
Also, if rad fan "cycles" turns on and off. it is a sign engine temp. is normal. 94
Old Jun 10, 2011 | 10:18 AM
I have a paper clip in it so the fans always on I just drove the car pretty far just got home the temp stayed normal idk seems like once the car is warmed up good it's fine but thanks for the help!
Wyatt Carter
Jun 5, 2017 09:50 PM
97civicdx
Jul 20, 2010 05:04 AM
Simmerman
12
Sep 18, 2007 07:05 PM
whiterex
Feb 28, 2005 02:57 PM
