Engine problem ... Help
Old Jun 19, 2011 | 02:36 PM
white_ej6's Avatar
Default Engine problem ... Help
hey look i bought this 97 integra with a 98 swap ...
i feel the motor has no compression .... when i push the motor as in push the gas alot to get speed all you hear is the motor forcing it's self ... if i do more then 45 the car starts smoking alot ... pure white smoke ... i go to the muffler and the fumes dont come out straightout how they should they come out like if the motor would be misfiring but it;s not
and it idles funny when it wants to .... i havent done a compression test because here in ny they want to charge 100 bucks just for a compression test i would like to know if anyone knows if it's the piston rings by the things i just explained ... also the muffler tip is black black like if it would be burning a lot of oil but it only burns a little ... like any other honda
Old Jun 19, 2011 | 02:56 PM
b18c4si's Avatar
Default Re: Engine problem ... Help
Hi , can you buy a compression tester ? i think you may be able to buy one for around $20 , im in the uk but just saw one on ebay for £10. At least then you can do a leakage check.
You could inspect the plugs for colour and oil.
Black in the exhaust is normally from running a little rich or being run on short journeys .
Smoke usually has a blue tint when its oil being burnt, unless very heavy.
white is usually water maybe indicating head gasket ?
hard to say with out seeing the smoke and doing a leakage test .
Good luck , hope this helps
Old Jun 19, 2011 | 03:00 PM
mark@silbernage's Avatar
white smoke: headgasket?
Old Jun 19, 2011 | 03:12 PM
b18c4si's Avatar
yes its called steam, can be confusing , hard to say with out seeing
Old Jun 19, 2011 | 04:57 PM
1998GsRIntegra's Avatar
So it sounds like its running rich and possibly has a blown head gasket.
Drain the oil. Is it a milky color? Like chocolate milk?
Are you throwing any CEL codes? My guess might be a bad primary O2 sensor.
When was the last time you checked your spark plugs? Are they black? Do they have any ash build up?
Old Jun 20, 2011 | 07:06 PM
el crapitan's Avatar
if the headgasket is leaking and compression is down, fuel won't get a proper burn. probably where your lack of power, black exhaust, and white smoke is coming from..if i had to guess
check your coolant level to see if it's dropped. check the oil dipstick for a milky substance. does the engine overheat?
as stated, a compression tester is fairly cheap and easy to operate. you should think about purchasing one
t0kyoStatus
35
Jun 28, 2008 11:58 AM
JDMtype Eg6
Jul 14, 2007 02:31 AM
sirguy01
Jul 6, 2006 09:03 PM
H23ludedude
Oct 21, 2002 10:41 PM
