Newbie needs help.
Old Jun 15, 2011 | 09:11 PM
kickinneon's Avatar
Default Newbie needs help.
I just picked up a 94 ls integra. The cel was so i jumped the wires to get the code/codes and i got
# 15 Ignition Output Signal
#41 Primary Oxygen Sensor Heater
I know replacing the o2 sensor will more then likely fix code 41. But my question is what do i need to do with code #15 to fix the problem.
Thanks for any help.
Old Jun 15, 2011 | 09:20 PM
kickinneon's Avatar
Default Re: Newbie needs help.
Disregard the above post. I went and rechecked the cel and it was code #14 IAC (EACV) – Idle Air Control Valve. ILL pull it off tomorrow and give it a good bath in carb cleaner.
Old Jun 16, 2011 | 09:12 AM
white_DB1's Avatar
My IACV was dirty as hell, I just bought a new one and idle perfect! I hate pulling up at a light and it idles crazy i get looked at for it lol.
Old Jun 16, 2011 | 09:31 AM
hybrid90's Avatar
You should change the subject title if you want more responses. Most people don't click posts like yours cause the subject is so vague. Just a suggestion...
Zen_Life
Apr 7, 2013 02:12 PM
SLEEPIN-GSR
Jun 23, 2009 02:06 PM
hatchedzex
May 24, 2004 05:12 PM
R-1303
Oct 25, 2003 05:13 PM
B00ST2nR
May 12, 2003 07:15 PM
