beaks kit help pls ?
Old Oct 10, 2003 | 09:04 AM
mckenzie's Avatar
Default beaks kit help pls ?
yes i have searched, 79 results on 3 pages, didn t have what i was looking for mainly ek, i have a dc/eg kit for a dc.
ok in pix nbr 2 would that how u install the beaks kit diretly on the sub frame or will it be pix nbr 3, with one of the gold plates in front of the frame, and the other plate behind it?
Old Oct 10, 2003 | 10:37 AM
Dan GSR's Avatar
Default Re: beaks kit help pls ? (egMee)
this is correct
one plate on outside side...the other plate on the inside
Old Oct 14, 2003 | 08:28 PM
mckenzie's Avatar
damn this kit is a bitch to install, the nuts are a pain to get out..anyone have a trick? i tried knocking them out while the bolt is still on
it..
http://hondatwincam.com/itr-srk.html good site for anyone who needs help.
Old Oct 14, 2003 | 08:48 PM
b18cu's Avatar
when you get it on you might want to check to see if the sway bar hits the abs brackets on the lca...mine did.
Old Oct 14, 2003 | 09:50 PM
Dan GSR's Avatar
the welded nutz are a three step attack...there are 4 tack welds for each nut
1. thread old bolt in half way...smack it with a hammer
2. hit nut with chisel/screwdriver
3. drill hole to finish off the last tack weld
works like a charm
Old Oct 14, 2003 | 11:17 PM
Bs's Avatar
Bs
Default Re: beaks kit help pls ? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Hit the head of the bolt straight on, and use a big hammer
Old Oct 15, 2003 | 01:29 PM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: beaks kit help pls ? (Bs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bs &raquo;</TD></TR><TR><TD CLASS="quote">
Hit the head of the bolt straight on, and use a big hammer </TD></TR></TABLE>
hahaha i was helping egmee do that yesterday. one of the tack welds didnt wanna come off and i smacked it hella hard and it kinda tore the hole a bit. lol. had to stop all the banging cuz my neighborhood is one of those "commitee policed" places and didnt wanna get written up for noise. damn committees. damn tack welds fat ITR sway?
Old Oct 15, 2003 | 04:15 PM
sfr4dr's Avatar
Default Re: beaks kit help pls ? (eeJayeiGht)
After using the above tactics on one side with only bad results, I took both LCA's all the way off and cut the tack welds with a dremel tool from the inside using a cutoff wheel and very steady hands. Then they practically fell off. Then I sanded any remaining weld off so the plates would sit perfectly flush.
Old Oct 18, 2003 | 04:18 PM
mckenzie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">the welded nutz are a three step attack...there are 4 tack welds for each nut
it works wonders, just kinda tears a little
finished the install took about 3-4 hours with only me., pls remember to grease the bushings i forgot and it sqeaks like a little monkey i ll get to it later
whiteteggy44
Dec 22, 2011 10:34 PM
SpeedoKing
Sep 20, 2011 09:53 PM
nosh2289crx
Nov 13, 2010 09:42 AM
dc2ls-vtec
Suspension & Brakes
Sep 10, 2009 08:49 PM
Propulsion
98
May 26, 2006 05:50 AM
