WAS I SCAMMED?!
Old Oct 8, 2003 | 02:16 AM
GSRHATCH187's Avatar
Default WAS I SCAMMED?!
well every1, i bought a swap out of a crashed salveage integra, and the guy said it was a obd2,(the motor) when i ended up takin it home i looked at the motor closely and it had p72 stickers and p72 engraved in a couple of spots, did i get a obd1 94-95 gsr motor? the computer said p72 on it also, does this mean that the motor is an older model?
Old Oct 8, 2003 | 03:32 AM
b18c1_powered_si's Avatar
Default Re: WAS I SCAMMED?! (GSRHATCH187)
p72 means it's a gsr swap. if u look at the ecu if it says "p72-A01" then it's a obd1 swap 94-95 if u wanted to know if it's obd2 then on the ecu it will say "A02" tha'ts for 96 motors. for 97+ it will be A03----98 is A04. u could also look at the head to id the year.
Old Oct 8, 2003 | 05:14 AM
YellowGiser's Avatar
Default Re: WAS I SCAMMED?! (b18c1_powered_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1_powered_si &raquo;</TD></TR><TR><TD CLASS="quote">p72 means it's a gsr swap. if u look at the ecu if it says "p72-A01" then it's a obd1 swap 94-95 if u wanted to know if it's obd2 then on the ecu it will say "A02" tha'ts for 96 motors. for 97+ it will be A03----98 is A04. u could also look at the head to id the year. </TD></TR></TABLE>
Does 96 gsr motor have anything tottaly different than the other years? Sorry for off topic.
Old Oct 8, 2003 | 07:49 AM
patmcd's Avatar
Default Re: WAS I SCAMMED?! (YellowGiser)
No, the b18 series motors stayed virtually the same with the exception of obd1 and odb2.
Old Oct 8, 2003 | 09:38 AM
where on the head is the year of the car?
Old Oct 8, 2003 | 09:57 AM
B U N M A N G O's Avatar
you can try checking the VIN #
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
If you unsure on anything about your Integra, chances are you can find out for sure from your Vehicle Identification Number. This guide is valid only for the USA market 3rd generation Integras, other markets and generations may differ.
Example VIN
JH4DB7561WS000001
Separate the VIN like so
JH4-DB7-5-6-1-W-S-000001
JH4=Honda Motor Co. Ltd. Acura Passenger Vehicle
DB7 = Body and engine type.
DB7: 4dr B18B
DB8: 4dr B18C
DC4: 2dr B18B
DC2: 2dr B18C
5= Body and transmission type
3: 2dr 5spd
4: 2dr auto
5: 4dr 5spd
6: 4dr auto
6= Vehicle grade
1: Type R
4: RS
5: LS
6: GS/SE
8: GS-R
9: GS-R w/ leather seats
1= check digit, disregard
W= Model year
R: 1994
S: 1995
T: 1996
V: 1997
W: 1998
X: 1999
Y: 2000
1: 2001
S= Factory Code
S: Suzuka, Japan
000001= serial number
Looking at the example VIN you can tell that the Integra is a 1998 GS 4dr manual.
taken from t-i
mkeacura
Aug 26, 2013 11:07 AM
GSR-TRBO-DA
May 26, 2007 09:25 PM
ATrin
18
Jul 31, 2006 05:38 AM
90HFCrX
Jun 9, 2004 09:20 AM
LHC
Nov 18, 2003 10:16 AM
