Nitrous Oxide For Integra
Old Oct 6, 2003 | 01:21 PM
player2z's Avatar
Default Nitrous Oxide For Integra
I ordered a zex kit and civic type r camshafts for my 95 gsr still in process. I was wondering what's the maximum psi shots my motor can take? What do I need to make it take a big enough shot? maybe 75 or more? i heard that 65 is average. can someone help me or give me info on what to do thanks
Old Oct 20, 2003 | 05:06 AM
GSRontheBottle's Avatar
Default Re: Nitrous Oxide For Integra (player2z)
Don't know much about ZEX but I ran 75 shot of Nitrous Express on my GSR and never had trouble.
Old Oct 20, 2003 | 09:10 AM
91tegrals's Avatar
i would try not to go over a 75 shot ..
Old Oct 20, 2003 | 09:11 AM
91tegrals's Avatar
oh and the psi on the bottle should not go over 1150 and normal would be around 950psi..
Old Oct 20, 2003 | 09:12 AM
neo1z's Avatar
Default Re: (91tegrals)
If you must run 75...you def need 2 step colder plugs and you need to retard the timing. I wouldnt go over 75 on a dry kit...when youre getting that high you might want to consider a direct port setup and more extensive fuel and ignition modifications.
Stick with 65.
Old Oct 20, 2003 | 09:36 AM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by player2z &raquo;</TD></TR><TR><TD CLASS="quote"> I was wondering what's the maximum psi shots my motor can take? </TD></TR></TABLE>
shots are not measured in PSI. psi refers to bottle pressure. When someone says a 65 shot that means a shot worth producing around 65 horsepower ..not 65 psi as you might have been thinking.
Old Oct 20, 2003 | 10:33 AM
naturelovindc2's Avatar
Default Re: Nitrous Oxide For Integra (J337_UNIT)
Me and my integra like to do shots of Jagermeister together.
[public service announcement]Drinking and driving is bad.[/public service announcement]
Old Oct 20, 2003 | 10:51 AM
quikB18B's Avatar
Default Re: Nitrous Oxide For Integra (naturelovindc2)
I would stay at 65, especially if its dry, which i beleive it is. Redlinegsr has been runnign the zex kit with no probs for about a year now, and pulling soem respectable times.
Old Oct 20, 2003 | 11:50 AM
2k1 GSR's Avatar
Default Re: Nitrous Oxide For Integra (quikB18B)
i have a 01 gsr with CTR cams and a zex 55 shot...it just gives me a little kick, im so tempted to try the 75 shot...
Old Oct 22, 2003 | 03:26 PM
91tegrals's Avatar
man i have seen people running 100shots on a b18b without a prob but its all up to you the amount of risk you are willing to take...
Old Oct 22, 2003 | 09:57 PM
Lewie's Avatar
I'm here for the gangbang!
I don't mean to sound like a *****, but all of these people aren't really giving you good advice. I'm guessing you don't have the kit yet, b/c the instructions give the best advice.
Both my friend and I have run the zex kit on a B18C1 with no problems. A 55 shot is normal, without colder spark plugs or retarding timing. To run a 65 you need colder plugs and retard the timing -2. To run a 75 you need colder plugs and retard the timing -4 degrees.
Yes, people do run 100 shots on stock motors....but not for long. If you want to run anything over 75 shot you are going to want at least new rods/rings/pistons. Also, if you run over 75 you probably want a direct port nitrous system, as that will ensure you get the right amount of shot to each cylinder.
Please search and follow the instructions.
Old Oct 22, 2003 | 10:47 PM
neo1z's Avatar
Default Re: (lewie4)
I just told him what Id do...Id be nervous shooting even a 55 shot without retarding the timing a degree and putting in at least one step colder plugs. Ugh Im a worrier though
Old Oct 22, 2003 | 10:49 PM
player2z's Avatar
I got it put it, i am running 55 shots rite now, will be squeezing higher when i get a new clutch!
Old Oct 23, 2003 | 10:22 AM
BrownGSR's Avatar
i have a zex kit for sale with purge valve, 350shipped
Old Oct 23, 2003 | 02:10 PM
player2z's Avatar
Default Re: Nitrous Oxide For Integra (BrownGSR)
thats a great offer but i have a kit already thanks
Old Oct 23, 2003 | 02:45 PM
Komsomol's Avatar
50 shot you should be fine. Play safe.
Don't forget to retard your timing 4 degrees or so.
Old Oct 27, 2003 | 09:17 PM
JDM_Risa's Avatar
Default Re: Nitrous Oxide For Integra (8400RPMS)
whats the best bottle pressure to be running for a 75 shot at night........my friend had his 50 shot bottle pressure at 1300 he said it pulled hard i squeeze his car when it was at 950 felt barely nothing my skunk stage 2 feel stronger.........
Old Oct 28, 2003 | 05:02 AM
B18bEK's Avatar
everyone PM mintegra97 and tell him to hook up his Nitrous, he's had it in his room for like 3 months!!
Old Oct 28, 2003 | 07:13 AM
DC2Slow's Avatar
im running nx wet 50shot best bottle pressure is between 1050-1150 i just use bkr7e plugs and replaced my clutch n flywheel
Old Apr 30, 2021 | 08:00 AM
Emanuel Rivera's Avatar
I'm running b18b1. 440cc at 55 psiWet fogger kit 80 hp shot in now and a 100 also on stand by depending how it does -8 pulled for timing for 3rd and 4th gear
what step plugs should I run one or two step colder please from someone who has experience or a kit in there car thank u guys n girls
Old May 2, 2021 | 11:06 PM
Bottlefedz28's Avatar
Loved
super old thread. But go to a 8 heat range. I’m not sure if these engines use projected tip plugs from the factory or non projected but a nitrous engine really needs a non projected plug so it doesn’t act like a glow plug. Start low on the timing and work up. Until it stops gaining as much power with each additional degree then take another out and you should be good. After each pull kill the engine immediately and check the plugs. Idle time will wash the fuel ring, even a little
0618turbocivic
Jul 25, 2006 08:38 AM
eg6rider
Mar 7, 2006 06:45 PM
mrbsponge
Sep 27, 2004 08:39 AM
f22suzuka
Jul 27, 2003 09:59 AM
Audio28
Dec 7, 2002 11:23 AM
