Quick Question for OIl
Old Oct 7, 2003 | 06:37 AM
N1NjA TuRtLE's Avatar
Default Quick Question for OIl
4 quarts of oil or 5 for GSR?
Old Oct 7, 2003 | 10:52 AM
Default Re: Quick Question for OIl (YellowSpoonEG6)
anyone?
Old Oct 7, 2003 | 10:53 AM
integ22's Avatar
4.25 quarts.
Old Oct 7, 2003 | 04:05 PM
Default Re: Quick Question for OIl (integ22)
k thanx, anyone put 5?
Old Oct 7, 2003 | 04:20 PM
Alexander's Avatar
negative! 4 is almost too much. 3.75 in my LS
Old Oct 7, 2003 | 04:35 PM
Rusty Shackleford's Avatar
Default Re: Quick Question for OIl (AVD23)
in the manual, an LS calls for 4 and a GSR calls for 4.2. regardless, you should always go with what the dipstick says. when i change mine, i usually pour almost 4 in then check the dipstick. if it needs more i will add it until its at the right level.
Old Oct 7, 2003 | 04:50 PM
Default Re: Quick Question for OIl (cpteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpteg &raquo;</TD></TR><TR><TD CLASS="quote">in the manual, an LS calls for 4 and a GSR calls for 4.2. regardless, you should always go with what the dipstick says. when i change mine, i usually pour almost 4 in then check the dipstick. if it needs more i will add it until its at the right level. </TD></TR></TABLE>
Thanx man, yea it's pretty common sense to just be checkin it, but i'm using Mobil 1 Syn, 4 quarts and when i checked the dipstick, it's calling for at least 1/4 to half a quart more.
kahriak
Dec 24, 2009 02:45 PM
Fooman
Dec 2, 2007 09:08 PM
viet1337
Apr 29, 2007 02:56 PM
iNtoXicaTedSPOON
Oct 4, 2004 07:41 PM
brickonwheels
May 18, 2004 10:44 PM
