rust on rotors?
Old Nov 24, 2003 | 11:41 PM
98DC2teg's Avatar
Default rust on rotors?
sorry i seached and didnt come up with any thing, does ne one now how to get the rust off of the front rotors. please help
nate
Old Nov 25, 2003 | 12:02 AM
Jowee's Avatar
Default Re: rust on rotors? (98DC2teg)
Drive around the block a few times and use your brakes.
Old Nov 25, 2003 | 12:29 AM
phuckinilltegie's Avatar
Default Re: rust on rotors? (ITR 98 1162)
word
Old Nov 25, 2003 | 12:32 AM
IntEGNYC's Avatar
Default Re: rust on rotors? (phuckinilltegie)
If you are referring to the areas where the brake pads do not make contact (i.e. Hub), remove your wheel and take a wire brush to it.
I finished it up by applying a coat of black high temp paint. No more rust for me
Old Nov 25, 2003 | 07:25 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">Drive around the block a few times and use your brakes.</TD></TR></TABLE>
ha yea, did you look at them after your car has been sitting? they ususally look like that, drive around and the brake pads will clean it up.
Old Nov 25, 2003 | 07:39 AM
dip-set's Avatar
Default Re: rust on rotors? (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">If you are referring to the areas where the brake pads do not make contact (i.e. Hub), remove your wheel and take a wire brush to it.
I finished it up by applying a coat of black high temp paint. No more rust for me </TD></TR></TABLE>
thats what i need to do...how did u mask off the area the pads touch?
Old Nov 25, 2003 | 12:46 PM
hotprep17's Avatar
Default Re: rust on rotors? (teg-your-it)
thanks ill go try that
nate
Old Nov 25, 2003 | 08:09 PM
DC4 teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i need to do...how did u mask off the area the pads touch?</TD></TR></TABLE>
some good ole masking tape no joke
gsr_pimp88
Sep 23, 2008 08:53 PM
BLUE EH3
16
Dec 25, 2006 10:40 AM
doodooheadfart
52
Jun 10, 2006 08:52 AM
VTECAcuraGSR
Apr 4, 2006 10:55 AM
piscorpio
May 23, 2003 11:09 AM
