Wiper Issues
Old Nov 24, 2003 | 08:10 PM
TheStryder's Avatar
Default Wiper Issues
for some reason my wiper dont work...at all. the only time they work is if i push down on the switch arm but none of the delay things work. anyone have any idea whats up with that?
Old Nov 25, 2003 | 06:55 AM
TheStryder's Avatar
Default Re: Wiper Issues (TheStryder)
can anyone help me?
Old Nov 25, 2003 | 08:49 AM
JimBlake's Avatar
Bad switch? Bad relay? Telling you what to check kinda depends on what year Integra you're talking about. You're gonna need a DMM so you can pull wires & check the circuits. We can't just tell from here which part is broken.
Old Nov 25, 2003 | 10:22 AM
jinu's Avatar
Default Re: Wiper Issues (JimBlake)
Since the switch still turns on the wipers we know for sure that's not it. First check the fuse, if it's not blown then check the relay it's right near the fuse box, if that's not burned, then it's your wiper motor.
BTW, if it turns out to be your wiper motor, I have a good one for sale, I had to go through the whole process last month.
Old Nov 25, 2003 | 10:38 AM
JimBlake's Avatar
Default Re: Wiper Issues (fangtl)
Actually, it's the same fuse for all different speeds. But I think the switch closes a different set of contacts when you push it down (single-stroke) vs. twisting the end of the stalk.
Old Nov 25, 2003 | 05:32 PM
TheStryder's Avatar
yea twisting the stalk doesnt do anything but when pushing it down the wipers work fine.
Old Nov 26, 2003 | 03:20 AM
JimBlake's Avatar
Can you check continuity thru the switch at each different position? What year Integra? The details probably are different...
black0hatch
Oct 11, 2012 11:52 PM
chunkybs
Jan 28, 2008 05:26 AM
go2sleep
Sep 2, 2007 10:08 AM
Luchini
Aug 9, 2006 02:25 PM
ANGELL
Aug 27, 2003 12:03 AM
