ls vtec
Old Nov 25, 2003 | 08:01 AM
SnkyPY's Avatar
Default ls vtec
im thinking of buying a gsr head for my ls, good idea?
Old Nov 25, 2003 | 08:07 AM
ggangtong81's Avatar
Default Re: ls vtec (98TegKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TegKid &raquo;</TD></TR><TR><TD CLASS="quote">im thinking of buying a gsr head for my ls, good idea?</TD></TR></TABLE>
hm...another ls/vtec...i can tell you rite now that you will get a lot of ugly replies like BAN , or search is your friend or whatever. but you should have searched first, but i think u should get b16 instead of b18 cuz of better flow.
search around.
Old Nov 25, 2003 | 08:09 AM
Full Race EG's Avatar
Default Re: ls vtec (ggangtong81)
if you dont want it to last the go for it. if you do, you will need to do some internals like rods, pistons and getting the crank balanced.
Old Nov 25, 2003 | 08:10 AM
XtremeCarTuner's Avatar
try this one- https://honda-tech.com/zerosearch look up LS Vtec.. theres a thread floating around here explaining the pros/cons of LsVtec. And if you want to buy parts go to the classifieds.
Old Nov 25, 2003 | 02:23 PM
riceball777's Avatar
go for it but i hope you know what your geting into
lsvtec's make great power and can be as reliable as any other honda motor thats only if it is build right
it will also cost a lot of money for a ls vtec build up and the head and block wont cost nearrly as much as all the parts and machine work
Old Nov 25, 2003 | 02:35 PM
Eviloliv3's Avatar
LS/Vtec doesnt last very long. theres a better solution... its called bored out GSR. you get the torque with more displacement, and the hp from the vtec. itll save you a load of heartache going this way instead of slapping a vtec head on a ls bottom end
Old Nov 25, 2003 | 02:37 PM
Mr. Softee's Avatar
Default Re: (Eviloliv3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eviloliv3 &raquo;</TD></TR><TR><TD CLASS="quote">LS/Vtec doesnt last very long. theres a better solution... its called bored out GSR. you get the torque with more displacement, and the hp from the vtec. itll save you a load of heartache going this way instead of slapping a vtec head on a ls bottom end</TD></TR></TABLE>
Even easier without thinning the sleeves dramatically is using an LS crank in a GSR block
Old Nov 25, 2003 | 02:40 PM
Eviloliv3's Avatar
Default Re: (94goldjungsr)
but then you wouldnt have the high revving capabilities of the gsr anymore, you are changing the shorter GSR crank for a longer LS crank, making everything not as stable.... i dont know if im puting this down right, it works in my head when i think about it
Old Nov 25, 2003 | 02:41 PM
Mr. Softee's Avatar
Ricer myth, plain and simple. There are people making over 600whp with LS cranks in GSR blocks.
Old Nov 25, 2003 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eviloliv3 &raquo;</TD></TR><TR><TD CLASS="quote">but then you wouldnt have the high revving capabilities of the gsr anymore, you are changing the shorter GSR crank for a longer LS crank, making everything not as stable.... i dont know if im puting this down right, it works in my head when i think about it</TD></TR></TABLE>
i hope you are not comparing the rod ratio of a ls and a gsr/itr
the lower rod ratio of a ls is so small and insignifficant it wont even affect the reving capabilities
the rod ratio is almost the same as a gsr and itr
that is like comparing the displacement of a ls and gsr/itr its so small
almost no difference
a b16 on the other hand is a 1.6 which will make a signifficant less torq that a 1.8 and the rr is i think 1.74 which is much higher than a 1.8 block
Old Nov 25, 2003 | 03:51 PM
thrty8street's Avatar
to solve the long rod/ratio problem of the ls/vtec, couldnt you replace the rods with gsr rods? wouldnt this correct the problem?
Old Nov 25, 2003 | 03:55 PM
Mr. Softee's Avatar
Default Re: (thrty8street)
No. You will have 0 piston to valve clearance, unless you run a deckplate. The problem doesnt need fixing in the first place.
Old Nov 25, 2003 | 04:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">to solve the long rod/ratio problem of the ls/vtec, couldnt you replace the rods with gsr rods? wouldnt this correct the problem?</TD></TR></TABLE>
first this is not really a problem and it doesent need fixing like i said the rod ratio is almost the same as a b18c block.
and no you cant run gsr rods unless you want the pistons hiting the valves
you can only run gsr rods with a gsr crank
Old Nov 25, 2003 | 04:06 PM
VTECorona's Avatar
Default Re: (riceball777)
If you do go the LS\VTEC route, make sure your builder is competent and knows what he\she is doing.
mike integra
Sep 28, 2008 05:26 AM
ek4ferrio
Oct 6, 2006 10:14 PM
jmoss1987
Jul 16, 2006 11:25 AM
mxler8
Jul 27, 2004 07:57 PM
xstalkrx
May 17, 2003 03:56 AM
