i got a problem advice needed
Old Nov 28, 2003 | 01:43 PM
slo2kgsr's Avatar
Default possible wheel bearing need advise
On my LS the pass tire when jacked up in the air can wiggle back and forth. Now i know it could be a wheel bearing, cause the axle nut is tighened the lugs are tight ect.... However the bushing between the lower control arm and the wheel hub has been popped could that cause it in any way. thanks
Old Nov 28, 2003 | 02:19 PM
AlphaKennyWun's Avatar
Default Re: possible wheel bearing need advise (tegraLS97)
Its probably the wheel bearing but if you think it might be the bushing then fix that first b/c its easier and cheaper, if its not fixed then get the wheel bearing fixed.
Unphzd
Dec 17, 2010 01:10 PM
RTW DC2R
Mar 25, 2008 06:10 PM
rbizzell30
Mar 19, 2008 12:11 PM
B18c1_turbo
Mar 14, 2008 10:43 AM
90H22
Jan 28, 2003 09:47 AM
